help converting air filter 91 firebird 305
Car: 1991 Firebird
Engine: stock 305
Transmission: Stock auto
Axle/Gears: stock
I have no experience with this at all and I want to convert from The stock intake over to this one I've bought. I basically just need someone to tell me how to go about doing it and if I need to buy anything else for it. Thanks.. I believe its the tbi.. I bought the 1208 proflow 10" edelbrock filter
1 Post
Car: 1991 GTA
Engine: LB9
Re: help converting air filter 91 firebird 305
It looks like it has a flat base, so it should drop right on.
Worst case, you might have to get a spacer ring to raise it up enough to clear the linkage.
Car: 1991 Firebird
Engine: stock 305
Axle/Gears: stock
I have no clue where to hook all of these hoses up lol im including pictures now that im at a computer.
Car: 1991 Firebird
Engine: stock 305
Axle/Gears: stock
and the last of the pics.. so anyone know what to do and can help me out
1 Post
Car: 1991 GTA
Engine: LB9
You can plug off the small vacuum line.
The large hose coming out of the valve cover can be routed into the bottom of the new air cleaner(kind of a pain), or replaced with your fancy breather.
You can just leave the heat riser on the manifold open.
I'm not sure on that electrical connection. My TBI truck does not have any electrical going into the air cleaner.
1 Post
Car: '91 Camaro RS
Engine: Carb'd 383
Transmission: Built T5
Axle/Gears: 3.73 Posi
That connection goes to the intake air temp sensor, just let that sensro hang somewhere close to the air intake.
Car: 1991 Firebird
Engine: stock 305
Axle/Gears: stock
1992 Trans Am
05-10-2023 07:19 PM
Zachattack0925
08-12-2015 09:54 PM
Zachattack0925
08-12-2015 09:52 PM
