85 camaro rebuilt 400 sbc problems
Car: 85 camaro z28
Engine: 400 sbc
hey guys im having a issue with my camaro i took it out for a bit yesterday ran great and once it got warm the car started to sputter when i gave it gas and the check engine light came on. this doesnt have any cataylac converters on it this did the same thing to me before i had the engine redone is this an electrical problem,or fuel problem any suggestions???
Re: 85 camaro rebuilt 400 sbc problems
Sounds like it needed a fuel filter before the new engine, and since the fuel filter didn't get changed in the process of swapping the motor, it STILL needs a new fuel filter.
But hey, you got a 400 out of the deal; so go change the fuel filter and enjoy it.
Car: 85 camaro z28
Engine: 400 sbc
its a work in progress allthough im having problems getting it to start up and crank over after i finally get it running it has no problems starting back up any suggestions. i did put it on a machine and it popped up two codes one being a maf sensor and tps sensor
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
You can replace the filter.. have fun because the threads are probably seized since who knows when or if it was ever serviced.
If this is a tpi car then connect a fuel pressure test gage to the schrader valve on the fuel rail... have a helper start the car or place the test gage so you can see it from the windshield..
Start the car and observe fuel pressure clogged filter or not... pressure should be steady at start up...give it some throttle, if the needle drops steadily you have a bad fuel pump..
The fact you are having start up issues if the first clue... fuel pumps don't last forever
Car: 1988 Formula
The MAF & TPS trouble codes can be a by-product of a bad fuel pump...
no fuel the ECM thinks it's lean (too much air and throws the MAF code & TPS code)
You will not get a "replace fuel pump code"
of course it does not hurt to check the TPS and MAF sensors to make sure they are in spec... that can be done with a voltmeter and search on this site. because I don't remember what the voltage ranges are.
Test the fuel pump by testing fuel pressure .replace the fuel filter and re-test the fuel pressure if the pressure is still dropping or low.. then you need a news fuel pump... otherwise you are wasting time reaplacing the wrong parts. although first step is make sure wiring to pump is good.. does the pump prime when you turn the key to run? (but not start the ignition) if the pump does not prime or sounds erratic this is anoter clue.
Car: 85 camaro z28
Engine: 400 sbc
the pump primes when the key is on i havent checked the pressure yet but it squirts out of the line pretty good when i push the nozzle on the rail. i replaced the fuel filter. i also have another question after it runs for about a minute or two the car starts idling faster and faster so i have to shut it off cause it sounds like it wants to blow lol. any suggestions on that
Car: 1988 Formula
IAC (idle air control) motor... I can't remember it the TPI cars have this..
this went bad on my TBI system (holley projection) but the idle was erratic.. not speeding up.
backtothe80s
09-05-2015 12:39 AM
92camaroJoe
08-13-2015 06:07 AM
