Headers make starter too hot after short drive
Car: 1989 Iroc-Z 350
After about a 20 minute drive if I turn the motor off I need to let the starter solenoid cool for 20+ minutes before I can restart it because it sits right next to the hot headers. I know I could put a heat shield on it but I think I would rather get a better starter that can handle the heat. Does anyone have a starter recommendation as I am not too familiar in this area.
1989 Iroc-Z
1989 Iroc-Z
1 Post
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
Re: Headers make starter too hot after short drive
I ran a mini high torque race starter but i also had high compression motor, it was just a house brand like $130.
1 Post
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Did this just start happening? Sounds like a bad starter. They do make starter shields to help keep heat away also.
1 Post
Axle/Gears: 3:42
Check with Summit racing, i think they sell starter sheilds or even heat wrap to protect things like your starter.
ive made starter heat shields out of welches grape juice cans. just an idea to save you a few bucks. headers wrap might be a good idea too?
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I also used heat shield tape on the front. Also good to 2000* blocking 90 percent radiant heat.
http://www.autozone.com/autozone/acc..._&target=shelf
My problems with heat soak are gone.
Car: 86 TRANSAM
Engine: 406
I used the foil faced blanket type and covered the whole starter. I am using a stock starter next to SLP 1.75 tubes. Time for a new starter now, after 9 years. The wrap will get brittle, so when installing new, just go right over the old one and double up.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
A well documented Chevy starter problem
http://www.streetrodstuff.com/Articl...tart_Problems/
http://www.chevyhiperformance.com/te..._no_start_fix/
The fix
https://www.thirdgen.org/solenoid
The fix
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Why not fix the problem that is making the headers too hot.
Headers should never get hot enough to bother the starter.
Putting a bandaid on doesn't seem right.
1 Post
Axle/Gears: 3:42
I had a similar problem with mine about a year ago, started getting harder and harder to re-start after the car was driven, the starter progressively got worse over time too until it finally wouldn't start at all.
db057
08-11-2015 10:11 PM
