Can this crank be cut?
Car: 1994 Z28
Engine: 355 LT1
I know this is hard to do without pulling measurements but I have no experience rebuilding a motor with a crank that is actually grooved (normally just send them out and have them polished).
The #4 & #5 rod bearings spun and grooved the journals in two spots; my finger nail catches it. I'm trying to avoid having to buy a new crank and have the rotating assembly rebalanced.
Car: 83 Z28 Crossfire
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: Can this crank be cut?
Holy crap!
Maybe it could be cut down enough to run some small journal rods!
That is beyond help imho.
Engine: 4++,350 & 305 CIs
If you cut it down to use the small Honda size rods you may be fine buuut I'd find another crank unless you know a person that is a great cast iron welder.
I might just be piling on here, but I'd cut my losses and get a balanced crank kit. If you really like your current rod/piston set, you could go the long way, get a crank, have it balanced, size and fit everything, and assemble it into the freshly hot-tanked block.
How did the cap fare?
Car: 1994 Z28
Engine: 355 LT1
I finally got around to measuring it. Never really had to measure a crank before cause I've always just sent them out to get polished and nothing more.
Well it measured 2.098-2.1 across most of the journals and the badly damaged one measured 2.045"... guess it's shot.
Ended up picking up another stock vortec rotating assembly for $50. Crank should be able to just get polished.
Car: 1994 Z28
Engine: 355 LT1
Out of curiosity I pulled the motor apart. Seeing the damage I snagged another crank/rods/pistons for $50. So after getting the crank polished ($77), picking up rod bearings ($26), main bearings ($26), freeze plugs ($13), cam bearings ($28 + $30 install=$58), rings ($130), rod bolts ($66) and having my rods resized ($140); I have a great starting platform for just over $700 and have $300 worth of parts that I need for another one of my vehicles and a set of vortec heads.
Not to mention most local junk yards or craigslist guys in this area want $400-$500 for a roller motor.
