How much HP before considering upgrading stock fuel pump? (fuel inj)
Car: 89 GTA
Engine: 350 LT1
Just lost the pump in my '89 TA. I'm also at the point of rebuilding the motor to make some more power.
I have an LT1 and plan on trickflow heads and possibly stroking it to 383..
A stock replacement here gets me a Bosch fuel pump but I'm wondering at what point should I consider a higher volume pump?
Thanks.
Thanks.
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
Re: How much HP before considering upgrading stock fuel pump? (fuel inj)
I am interested in this as well! I would like to know for what I could bump my nitrous up to.
Thanks.
Thanks.
I believe its rated at 150 lph. A 255 lph pump supports 600 hp. A 150 should do 400. Some say 450, as 150 lph is close to 248 lbs /hr fuel and by calculations you get a theoretical max of 475-500 hp but that seems optimistic to me. Also assumes 100% duty cycle on injectors. 400-450 is abit more realistic and you maybe within that realm of power with a 383
Car: 89 GTA
Engine: 350 LT1
Thanks.. sounds like I'll play it safe and upgrade.. Always good to check, often bigger doesn't always mean better or is necessary.
I actually ran my Walbro 255 with my stock TBI 305 motor for a couple of years because I knew I would be putting a 355 Tuned Port motor in soon. The stock TBI fuel pressure regulator kept the pressure where it needed to be, even with the high pressure/high volume pump, so it wasn't a problem.
theshackle
03-05-2017 06:37 PM
AkDrifted
08-17-2015 07:45 PM
92camaroJoe
08-13-2015 06:07 AM
