90MPH AT 5000RPM...???Somethings WRONG?
1 Post
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
Alright so Ive asked this question in the [past but I still haven't been able to solve my issue. and yes ive checked my tach connections and everything is fine. I am running an aftermarket Sunpro Tach and everything is wired right but I still dont know as to why my engine revs so high at those speeds..I got a T5 tranny with a 305 LG4 engine and even at 70mph its reving at arounf 4000RPM's. Earlier today I gunned it to 90MPH and I was already at 5000RPMS's so im pretty much limited to how fast I can go because Ill be red lining it by the time I hit 95mph.....
For the rear to my knowledge I know for a fact I have a non posi unit and I am about 95% sure I have stock gears...Anyone might know why this is happening...Or is this just how the car is??IM PRETTY PUZZLED ON AS TO WHAT IT MIGHT BE?
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 90MPH AT 5000RPM...???Somethings WRONG?
If you put the right numbers in
http://www.bgsoflex.com/rpmmph.html
here it will tell you what rpm you should be doing at what speed
About time you checked it out ; might solve all your guesses
This is going on the assumption that some common sense has been exercised and your not simply trusting a cheap tach. I would hope you can hear and feel the difference between 5000rpm and 2500rpm without a tach.
Its simple math, there isn't going to be a "diagnosis" here....your either running 410 gears, or your not actually in 5th gear. This is going on the assumption that some common sense has been exercised and your not simply trusting a cheap tach. I would hope you can hear and feel the difference between 5000rpm and 2500rpm without a tach.
Bizarro explanations that are unlikely would be:
1. massive clutch slippage... MASSIVE.
2. 5th gear ratio is the same as 3rd gear.
3. 13 inch diameter wheels + tires.
Seriously man... does it SOUND like 5000 RPMS? Thats well on up there, you should know if it's really that high. Your engine shouldnt want to run much past that anyway.
Also, dont be an idiot and drive around at 90+ mph on the road.
1 Post
Car: 1984 Z28
Well Im not relying all my senses on the tach I can literally hear my engine roaring at those speeds even @ 70mph when im on the freeway I can hear 4000RPMS......so thats why when Im driving I rarely pass 70 just because of my rpms.
and the tach is set correctly.
1 Post
Car: 1984 Z28
and as for my tires and rims I have 245/60/15 on the back and 235/60/16 in the front.
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
going with infernal on this one...
1 massive clutch slippage
2 you are shifting from 4 to 3 thinking it is 5...
3 your tach is wrong and you dont know what 5k rpms sounds like...
or maybe the ring and pinion switched themselves for a set of 4.11s oh wait they cant do that! because you would have seen them pulling themselves out and it would have made a huge mess... they never remember to get the oil pan in before spilling the oil everywhere
If your 3rd gear is around 1.3 (pretty normal) AND you have 3.73 rear gears (unusual... but possible) you will be at 4000 RPMs at 65 mph in third gear. Do the revs go DOWN from 4th to 5th? It sounds liek you're in 3rd gear to me if what you're saying is correct.
If you're in 5th gear and it's around a .75 ratio (not positive on T5's, but it should be in that neighborhood), then your rear gears would have be OVER 5.xx to hit 4000 RPM at 70mph.
What is it doing in 4th gear? Is it possible your 5th gear is busted and its putting you into 3rd gear?
Car: 91 RS
Engine: 350 vortec
it wont engage a lower gear if 5th is gone... shifter will move into place but there just wont be anything there like neutral... or horrible noises before nothing is there.
maybe reverse lockout solenoid? no idea if it is possible
but to not notice the hugely jaring shift from 4 to 3 at 55+mph is harder to believe
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
yeah its a rear gear, tach, tranny gears or massive slip but you would feel that! What speeds and rpms do you have in the other gears?
Car: 91 RS
Engine: 350 vortec
there is no way someone mistakes 160MPH for 90... especially in a thirdgen! if that is what happened please head to the nearest state trooper to hand in your license... hopefully you can do that without killing either of you...
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
Yeah i very much doubt the car would even go that fast! And if it did im sure if u go 70 in a 75 and you are flying by people like they are standing still you would know what the problem is. Along with the what is 5k in every gear does the car seem to be stupid fast off the line and you have to shift really fast?
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
honestly if you dont know what the rear gear is I would say someone before you just smashed so crazy gears in it!
Even if he has a shorter .73 gear in it, to hit 4000 RPMs at 70 MPH means he has rear axle gear between 5.95 and 6.05. That's insane. I dont want to be too presumptuous but I cant even imagine ratios near 6.00 even exist for the 10-bolt...
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
Except if its a v6 tranny or if it had the tranny gears played with.
From a quick check in the T5 faq thread, even v6 t5's got either a .73 or .78 5th gear ratio, which puts us right back at a 6.00 rear gear. Thats clearly unlikely.
Although I do like the idea of a prankster setting the 5th gear ratios to the same as 3rd gear for the lulz.
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
So whats your idea that it is cause you havent givin any advice yet haha all im saying is that it has to have something with the gears if he answers the questions soon it will be easier to learn more about it cause if 4th is lower then 5th thats easy if not there is more to it whether its gears or crazy slip...
Car: 82 Z28
Transmission: T400
Bottom line, what the OP is seeing is not correct.
Time for tcalgutie to do the fundamental tests outlined above to determine WHY
Until he comes back and states what the rear and speedo vs rpm checked out to anything else is pure SPECULATION
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
Have you read my posts?! All I have done is find where the problem could be and ask questions that havent been answered yet by him to find out what it is. I said check... READ!
