Oil catch can pipe length?
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
Im going to install an oil catch can, but the only spare place to mount it, is on the drivers side right behind the headlights. This means the tubing running to the PCV and manifold will be in excess of 1.5M. Is this too long?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Oil catch can pipe length?
Should hold about a quart to be safe but there is no specific size required.
Car: '92 RS Camaro
Transmission: TH400
You misunderstood, its the length of the pipe goin to the can Im worried about
Car: 87 IROC L98
When I used to run header evac, the hoses running from the valve covers to the collector valves were close to 3 feet long each.
Hotrodboba400
12-10-2019 07:07 PM
