58mm Throttle Body Swap Question
This car now has a 58mm Holley on it. Just wondering if this throttle body could cause a lean condition on start-up when the car is warmed-up? I read this: http://static.summitracing.com/globa...99r10020-2.pdf
but it didn't mention this as a potential problem.
Grasping at everything now with the problem....
Re: 58mm Throttle Body Swap Question
One thing stated repeatedly in the Paxton manual is that the system is designed to be used with the stock "chip" and not to use anything other than that.
Getting a fuel pressure gauge Tuesday, so I can double check.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
The engine will only draw what air it needs and the injectors will supply fuel as programmed
Any codes showing?
Terrell351
06-13-2021 01:13 PM
Fast355
12-02-2016 06:33 PM
