Cam and compression ratio compatibility
Now look guys.Ya gotta start learning this stuff and learn about cams in general.You have the net access and a whole host of resources because of it.I think you should use it.Apart of Hot Roddding is learning it and not choosing parts by general consensuses or by jury.
From Crankshaft Coalition Wiki
Jump to: navigation, search
by: Cobalt327, Jon, Silver Surfer, Techinspector1
(Click here to edit this page anonymously, or register a username to be credited for your work.)
Sometimes it's difficult trying to explain to fellows who are new to hot rodding that you have to match the characteristics of the camshaft to the static compression ratio of the motor along with the operating range where the cam makes power. The camshaft is not a stand-alone piece. It must be coordinated with other motor and drivetrain parts in order to arrive at a combination of parts that will all work together toward a common goal.
This chart is nowhere near scientific or definitive in its scope. Larger or smaller cubic inches, different lobe separation angles and other variables will alter these figures, but at least it's a starting point in the explanation of using a certain range of cam with a certain range of static compression ratio. The figures shown in degrees are camshaft degrees of duration measured at 0.050" tappet lift.
The chart will show why it is foolish to install a 230 degree cam in an 8.00:1 motor in an attempt to get a lope out of the motor. It might lope, but it will lack the power to pull the hat off your head. There seems to be an obsession with lope these days. Lope is simply the sound of the motor being inefficient at low rpm's because the ascending piston is pushing fuel/air mixture back up the intake tract through the still open intake valve and disrupting the metering abilities of the carburetor.
On the other hand, it's equally as foolish to install a short cam into a motor with a fairly high static compression ratio. You get into an area of such high cylinder pressure that no fuel short of alcohol or racing gasoline will prevent detonation.
You can move 1/2 point of SCR either way and be in the ballpark. In other words, if you have a 9.00:1 motor and you want a little more cam, you can move up to a cam that would be used in a 9.5:1 motor and be OK. On the other hand, if you wanted to go with a little less cam, you might use 1/2 point less compression, down to an 8.50:1 cam.
Crane says:
Crane says:
Why is it necessary to know the Compression Ratio of an engine in order to choose the correct cam?
The compression ratio of the engine is one of three key factors in determining the engine's cylinder pressure. The other two are the duration of the camshaft (at .050" lifter rise) and the position of the cam in the engine (advanced or retarded). The result of how these three factors interact with one another is the amount of cylinder pressure the engine will generate. (This is usually expressed as the "cranking pressure" that can be measured with a gauge installed in the spark plug hole.)
It is important to be sure that the engine's compression ratio matches the recommended ratio for the cam you are selecting. Too little compression ratio (or too much duration) will cause the cylinder pressure to drop. This will lower the power output of the engine.
With too much compression ratio (or too little duration) the cylinder pressure will be too high, causing pre-ignition and detonation. This condition could severely damage engine components.
Static Compression Ratio (SCR) Intake Valve Duration (degrees @ .050" lift) Power Range (RPM) 8.00:1 185º 500-4,000 8.25:1 189º 650-4300 8.50:1 194º 800-4,500 8.75:1 200º 900-4,600 9.00:1 204º 1,000-4,600 9.25:1 208º 1,200-5,200 9.50:1 212º 1,600-5,400 9.75:1 216º 1,800-5,600 10.00:1 221º 2,000-5,800 10.25:1 227º 2,400-6,200 10.50:1 233º 2,800-6,400 10.75:1 236º 3,000-6,800 11.00:1 240º 3,200-7,000 11.50:1 244º 3,400-7,200 12.00:1 248º 3,600-7,400
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Re: Cam and compression ratio compatibility
Pretty good guidelines assuming everyone has good 93 oct gas although it should run ok on 91 that some areas have. E85 guys can almost run a full point higher
Car: 1983 G20 Chevy
Transmission: 4L60
Not only can we run higher compression, we can run proportionally leaner mixtures without detonating and have the benefit of the vaporization of the additional fuel cooling the intake charge more than gasoline would.
Car: 89 Iroc-z
Transmission: TH400
Yup superior for power making with its coolin effects and octane increase. Too bad its not available in some areas where pump gas is everywhere. Fuel system design for E85 should be abit more expensive to handle the alcohol
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Here I was thinking I'd finally make a cam post so all the "what cam should I run" questions go away, hahah.
Gary, you beat me to it.
Car: 1983 G20 Chevy
Transmission: 4L60
For a 5,350 lbs 4 door truck that came stock with 317 HP only adding a CAI, exhaust, tuning, and a few other free/inexpensive mods it flies.
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 89 Iroc-z
Transmission: TH400
I know what you mean. Got a L9H 6.2 truck myself and with tune only it made 330 whp. Gas tune only never tried e85. Thats thru 6l80e and 14 bolt 2500 rear. It gets up quick
Car: 1988 gta
Engine: 383
Axle/Gears: 9 bolt 3:23
Good basic guideline, but there are variables that can alter things a bit.
Without asking what cam should I run, I was thinking of installing what I want, spinning the engine on the stand , and using cranking compression as an indicator. If it's under 200, I'm probably good to go?
Car: 89 Iroc-z
Transmission: TH400
That probably will work, i have heard other motors running with well over 200 psi on pump. You can also dial in spark plug heat range and use timing and fuel ratio to bandaid everything else
Hotrodboba400
12-10-2019 08:07 PM
UltRoadWarrior9
09-02-2015 09:24 PM
