hot wire fuel pump through ALDL terminal G
Car: 1983 Z28/2000 ZR2
Engine: CFI to carbed 305/ 4.3
Transmission: Built 700r4/4L60e
Axle/Gears: 3:23/3:73
I have a bad OPSU in my 83 Camaro; the car looses fuel pressure and dies after the initial prime. My car is in storage and I will not be able to fix this problem until spring. HOWEVER, the car is started and run daily for a good amount of time at its current location. My question: Will there be any effects on my fuel pump if a 12V key on source of power is run to terminal g? I just don't feel like having to replace my new pump come spring as well. Thanks guys!
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: hot wire fuel pump through ALDL terminal G
so no different for pump than when relay is powered up by the computer.
( except the pump will run full time even with Ign off )
If the pump relay is working properly you could wire 12V to terminal G through a push button switch so you can
run the pump to prime /start the car then let the ECM run the pump .
That way when you turn the engine off you don't have to remember to kill the pump
theshackle
03-05-2017 06:37 PM
92camaroJoe
08-13-2015 06:07 AM
