85 power steering
Car: 1985 IROC Z
Engine: 305 F/I
Transmission: auto
85 power steering
bought a 85 Z 305 TPI couple months back an i've tore it down to redo myself an who every had it took out the power steering line that ran under the radiator an rid up some bs i've got it all ready to go in but i dont know how to run the lines it has a rally an i need help or pics on what it looks like an how to do it cuz i'm not a lover of that line running on the bottom of the car.THANX
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: 85 power steering
I would like to help but the first step in your repair is using punctuation and the shift key.
Car: 1985 IROC Z
Engine: 305 F/I
Transmission: auto
I ask for some advice an look what I find "KING DOUCEBAG" thanks that really helped!!
Last edited by rockin the z; 01-02-2013 at 01:12 AM. Reason: i was wrong on spelling
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F
that line cools the power steering fluid, you need it or you'll boil your fluid. It's down there because that's where the best airflow for it is. Just reinstall it in the factory location that you removed it from.
You should also invest in a "HELM" factory manual, they run about $100 on Ebay and it's the same manual the factory and dealers use to fix these cars.
Also, while skirkland may have been a bit Crass, punctuation really is your best friend.
Yes. Reading who knows how many sentences with no periods is not worth reading. Also, why send me a private message? I'm just going to post it here. Is this your first car?
reply
stay down there an **** ur sister or whatever u ****in lames do an stay the **** off websites where people are trying to do something other than impregnate the family goat!!!
reply
Car: 1984 Trans Am
reply
reply
Squeaky8791
02-05-2020 08:29 PM
Chuck84TA
07-15-2016 09:05 PM
evilstuie
04-14-2016 08:52 PM
