How to protect starter wires from exhaust?
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Since my engine swap has been completed Iv been scared about how close my starter wires are too my exhaust manifolds an y pipe, how do you guys keep your wires from getting to the exhaust? It seems like the loom and wires are against the pipe an I don't want to take the car out and have the wires get melted and leave me stranded. And I can't zip tie the wires away from the exhaust because there is nothing they for me to zip tie them too.
Re: How to protect starter wires from exhaust?
You can put your wires inside of heat or fire sleeves. Search Summit or Jeg's.
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
I first put the wires in plastic split loom. Then I covered the loom to protect it from heat with aluminum tape, about 2" wide with adhesive on one side. Got it from Home Depot. I went this route because the plastic loom insulates the wires well, the aluminum tape gives good heat protection, and in combination it's very easy to remove if you ever need to get in there.
1 Post
Car: 92 Z28
Engine: Boosted LSX
Some good stuff to use. How far do you want to go..
Get this put wires in it....
http://www.summitracing.com/parts/dei-010421/overview/
Slip these over wiresin the dei tube
http://www.summitracing.com/parts/the-14250/overview/
wrap it all once done with this..
http://www.summitracing.com/search/p...mo-shield-tape
Will never have to worry about it again.
Engine: L31 350
the wires are loomed already, just alittle too close to comfort for me, i thought about using header wrap to wrap the wires since those are the only wires i have no( carbed motor) that i have anywhere near the exhaust.
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
a lot of cars and trucks came with a steel tube that bolted to either the closest bellhousing bolt or the solenoid mounting screw that routed the wires away from the exhaust and protected them, but you can generally just find a way to route them and maybe hold them up against something with a zip tie.
Street Lethal
08-13-2015 08:28 PM
db057
08-11-2015 10:11 PM
