Turbo Set Up
Old 12-05-2012, 11:38 AM
  #51
TGO - 10 Year Member
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Re: Turbo Set Up
Originally Posted by 1992PonFirebird
I had plans of running an intercooler. So would you say use Turbo diesel oil? Should I do a do a oil cooler? And so you think I should run 6psi or would I be fine with running 8psi?
Dont have to run diesel oil. I ran syn 10w-30 and 15w-50 before in my motor. Once i add oil cooler i may go back to regular car synthetics.
Your setup i'd run a wastegate set at 6 psi for initial running and see where it gets you. If you need abit more, manual controller for 2 psi more. 6-9 should run and make for a very fun setup
Old 12-05-2012, 12:15 PM
  #52
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: Turbo Set Up
I would never consider slapping a turbo on until I addressed the rearend and transmission integrity issues you're definitely going to run into.. BOTH of which will blow your budget out of the water if you thought $2K for decent cylinder heads was bad. You WILL blow one/both of them up with that kind of setup if it isn't built it handle it. That, and you're going to want a good rotating assembly in order to address the desire for power. I'm not saying it shouldn't be done (I considered a procharger for myself) but BUDGET and POWERADDER are not friendly in the same sentence together.
You're talking about an expensive build, not just something that you can throw together and watch it work. I'm not talking down to you, but it's critically important you take into account everyone else's safety and not just yours. You'll be driving this on the street (and strip) and the last thing anyone wants to see is something blowing up and sending you into the other lane of traffic at 65 MPH simply because you couldn't afford to do things properly.
I support your build, just.. be smart AND realistic about it.
Old 12-05-2012, 12:29 PM
  #53
1gary's Avatar
Re: Turbo Set Up
I am going to adapt a new term.I is a "open book build". You acquire all the needed parts over time and add up the costs at the end of the build.No time limits....................whatever it takes.
Old 12-05-2012, 12:40 PM
  #54
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: Turbo Set Up
Thats how i did it. To do what i did at once would cost over 35k
Old 12-05-2012, 01:50 PM
  #55
1992PonFirebird's Avatar
Car: 1992 Pontiac Firebird
Engine: 400 sbc
Axle/Gears: 3.73 Limited-Slip
Re: Turbo Set Up
Exactly if I did everything that I wanted I would have easily 30 to 40k in it but not many people have that money to just blow through and I already have a ford 9in rear end with 3.73 gears and if you read throw the thread you will read that I put in there that when I take out my tranny I am going to beef it up. So before you go posting **** actually read all the posts.
Old 12-05-2012, 01:51 PM
  #56
Engine: 400 sbc
Re: Turbo Set Up
Part of a build is taking time. I'm not rushing anything right now because I want to build things right and good.
Old 12-05-2012, 01:53 PM
  #57
Engine: 400 sbc
Re: Turbo Set Up
Originally Posted by 88FormulaF_Bomb
then why turbo it? you can ruin that block with a good set of heads and a 11:1 compression without the added expense and hassle of going forced induction. there are easier ways to achieve 4-500 hp with 400 cubic inches. but i respect your decision to do what you do, and have fun doing it.
Posted from Thirdgen.org App for Android
READ ALL OF THE POSTS! I know I can get that much out of all motor but living up in Colorado the air gets thinner the higher you go and so it's better to have a turbo to get that air
Old 12-05-2012, 02:06 PM
  #58
Engine: 400 sbc
Re: Turbo Set Up
Orr89RocZ- I just traded with one of my friends my turbo for a brand new 70mm trim Turbonetics
Old 12-05-2012, 02:10 PM
  #59
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: Turbo Set Up
Cool post up more info on it, does it have a part number? Pics?
Old 12-05-2012, 02:16 PM
  #60
Engine: 400 sbc
Re: Turbo Set Up
I will post all the specs when I get them. I will try and get a picture from him tonight. He is away on a trip right now but as soon as he gets back I will make sure to post pictures and specs.
Old 12-05-2012, 02:24 PM
  #61
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
Re: Turbo Set Up
i'm doing an open book build myself ....
best of luck ...
Old 12-05-2012, 02:37 PM
  #62
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
Re: Turbo Set Up
You didn't say that at all. Go back and read your post again. You said "My brother and I will rebuild the motor when I pull the 305 out and he said he knew somethings that he could get from his shop to "beef" it up some more." What's that supposed to mean? Subframe connectors? Rebuilding a 7.5 and putting a girdle on it with a brace? Putting a "posi unit" in? Painting it with a toothbrush so it looks stronger? What? That doesn't tell anyone ANYTHING.
You're asking DUMB questions when it comes to doing this whole build, yet we are supposed to assume that you magically have everything else lined up correctly? I'm not anywhere NEAR qualified to call myself "experienced" with power-adders, but even I know better. GO READ A BOOK, THEN ASK. Stop being a lazy **** and actually do your homework instead of getting random opinions about a serious build that you have ZERO experience with doing.
You come in and post on here like you know everything and you're an expert with so many things, yet you're talking about doing dumbass things like pushing massive amounts of boost through a tiny-*** trim with hypereutectic pistons on stock cylinder heads and using junkass rods and still expect umteenmillion horsepower.. all while getting defensive when someone tells you something you don't like. I seriously doubt you've ever had this kind of power because you talk about it like it's no big deal.
Before you decide to make a stupid remark, at least think about things before hand... seems like you have a lot of trouble with that.
Old 12-05-2012, 03:15 PM
  #63
1gary's Avatar
Re: Turbo Set Up
Delta-honestly some of those dumb questions where generated about turbos by me for Orr to answer.
Old 12-05-2012, 04:35 PM
  #64
Engine: 400 sbc
Re: Turbo Set Up
1gary- Those questions will help out any person that doesn't know to much about turbos that gets on this thread. Some of those questions help me too so no worries. Delta just thinks he is so cool and knows everything because he works in a paintball shop. He isn't worth anytime.
Terrell351
06-13-2021 01:13 PM
Street Lethal
04-30-2019 12:14 PM
lt1z350
09-29-2015 01:50 PM
camaro71633
09-01-2015 10:24 AM
mustangdmurder
08-21-2015 07:17 PM
Quick Reply: Turbo Set Up
