Scared to start my rebuilt engine
Car: 87 firebird did V8 swap
Engine: sbc 350
Transmission: 700r4 shift kit and stall
What would happen if I put a connecting rod cap on wrong I don't kno if I did just hoping I didn't would the engine rotate or would it lock up after a little
Car: 1988 firebird formula 350
Axle/Gears: 2.77
first build jitters? im sure if you had someone with real experience guide you through the assembly,everything will turn out okay. start it. if it knocks turn it off.
Posted from Thirdgen.org App for Android
Engine: sbc 350
Re: Scared to start my rebuilt engine
I started it it sounds fine but it wont stay running unless u tinker with the carb and keeps puff smoke out of carb when it dies any ideas could my distributor b a tooth off or something
1 Post
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Sounds like your timing is too far retarded. Turn dizzy slightly CCW, start and immediately check timing.
Engine: sbc 350
ya it was a whole tooth off turn it one tooth on cam started right up and sat and ran but now im only getting fuel for a little then it cuts off and make the car shut off any ideas
What kind of factory fuel pump was in it ? Was it ever removed ?
What kind of pump are you using NOW ?? Where is the fuel pump mounted NOW ??
Still got the original Canister type "in-line" Fuel Filter installed ?? Got any other additional fuel filters on the fuel line ??
Are you SURE that it's got plenty in the tank and that it's fuel starvation causing the car to stall?
How did you get the fuel line to connect from engine bay fuel line to the carb ??
Engine: sbc 350
I'm running a mechanical one on the block and it has the stock canister in line filter and has fuel pump in the tank still and I just put gas in it before I started it and when it stutters an dies I open the carb and there's no fuel coming out of the jets I have to jump in in tank one and turn the motor over to get fuel again
My first guess is that the original in-tank pump is the problem. I NEVER leave the in-tank pump in place when converting from FI to Carb. The block mouted pump is trying to pull the fuel though the original in-tank pump.
I'd also recomend installing a new canister fuel filter while your under the car. I doubt a blockage is the problem - but a new filter will eliminate that possibility.
Engine: sbc 350
ok thanks what i think would b harder to get the stock pump out ortake the whole stock tank out and mount a fuel cell in its position cause i have a good summit racing fuel cell thatll work that i got for the car but didnt kno if it was a good idea
yea, drop the tank and go from there. you could pull the electric pump out of the stock tank and fab up a pick-up for it. its pretty easy to do.
heres a good video on setting your timing.
1 Post
Car: '72 Chevy Nova
Transmission: TH350
Just drop your stock tank, pull the elec pump and fap up a pickup.
Engine: sbc 350
What would b wrong with putting the fuel cell in my tank sending unit doesn't work anyways
Jw
Jw
backtothe80s
09-05-2015 12:39 AM
