Advanced timing to 12 and now idles at 2000...?
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
So the other day I advanced my timing to about 12 degress and it seems to like it there but the problem is that my engine is low idling at 2000RPM's.....?how can I lower it?
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Re: Advanced timing to 12 and now idles at 2000...?
It's a carb? If so then just back the idle adjustment screw out a little. You're not using a computer controlled distributor are you? When you switch to regular carb you need to switch to a distributor with vacuum advance capability.
eightsixseven
08-14-2015 03:09 PM
