hard starting
Car: 1992 camaro rs
Engine: 3.1 v6 MFI
Transmission: 5 speed
Axle/Gears: poss rear end
hard starting
i have a 92 camaro rs 3.1 v6 tbi. the other day car started missing. with a little backfire from time to time . i run it for 15 miles that way then it runs fine. this morning it tryed to start then died real fast. after 5 attempts it started, but had to keep on the gas pedal. then after a few minutes it will idal. new plugs,wires cap,button,module , fuel pump,coil. anyone help. could it be the choke? need help plz
Car: 1991 RS
Engine: L69?
Re: hard starting
That sounds like a possible timing issue. I'm still trying to get mine dialed in as well and have similar symptoms. Might wanna check it to be sure.
Re: hard starting
Those don't have a choke.
Get a fuel pressure gauge & test the fuel pressure, should be from 35-45psi. Might be a bad fuel pressure regulator. Test it first before buying anything else.
Is the check eng. light on?
Car: 1992 camaro rs
Engine: 3.1 v6 MFI
Re: hard starting
went to chevy garage assured me it was map sensor causing my problem. gettin one today will post to let everyone know if it helps
92camaroJoe
08-13-2015 06:07 AM
