Hesitation and stalling
Car: 86 chevy 28 camaro
Engine: 305 tpi
My 86camaro z28 tpi camaro is running terrible. It idles fine but when i accelerarte it craps out really bad or stalls. Whats a cheap fix to start with? I appreciate any help.
Re: Hesitation and stalling
Check the fuel pressure, dirty maf sensor, test the tps from idle to wot.
You'll need a gauge to test the fuel pressure, you can rent one at autozone.
You'll need a muitimeter to test the tps.
Engine: 305 tpi
I put a new tps on it. Ok i will do that. If i have to replace the fuel pump is there a easier way to drop the tank then the axle job?
Some have made access holes, but to make a hole for the 1st time, your best to drop the tank because you have to modify the long steel sending unit lines. Do a search, theres lots of picturs out there.
Car: 91 camaro rs v8
Engine: 305,5.0 liter
Axle/Gears: 10 bolt 355
being that uv replaced the tps,u might not have the correct voltage ,on this site it tells u how to get correct voltage an test your tps by setting it with 2 wires an an amp tester ,an turning the tps till uv got propper voltage then tighten the 2 screws u losened in that position
RedLeader289
05-28-2019 01:47 PM
darwinprice
17
10-11-2015 11:51 PM
HoosierinWA
10-07-2015 10:15 AM
