difference in 67-85 350s and 86-98 350s
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
can anyone tell me a difference in them? im looking at a re ring kit for my block but im finding more of the 67-85 kits than one for my 96 block. whats the difference??
Re: difference in 67-85 350s and 86-98 350s
Intake bolt pattern, angle, & how many bolts, TPI, TBI, computer contnrolled carb or non computer controlled carb, same with distributor, factory roller cam, flat tappet cam
( hydraulic ).
Thats all I can think of. IDK piston, rings, bearings.
( hydraulic ).
Engine: L31 350
i think all the bearings and rings are okay, but im more worried about the gaskets, like the rear main seal, are the older blocks 1 peice seal or 2 peice? are all the gaskets the same?
Older blocks are 2 piece. Rings pistons etc the same.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
86+ engines are one piece RMS.
There are no 85 z28 350s.
Eric-86sc
08-24-2015 09:01 PM
