Whine, whistling, turbo sound???
Car: 91 camaro rs
Engine: 305 (350 vortec in dec.)
Transmission: Wc-T5
Axle/Gears: 3.08 (3.42 in dec.)
I have had my camaro for a year or so... It turns out to be a salvage rebuild... The title was not a nc title it was a Texas title, so as it comes back to nc it has to be posted on the title as salvage rebuild. Anyways, it has bad valves seals and runs bad, well boggy. When you gun it, there's no get up and go. My 92 was exactlythe same setup.... T5, 308's, 305 tbi.... And it was a beast, very quick. Well someone welded the muffler on backwards, po.... And when I removed it I was getting the same "bogginess", so I checked the cat... The insides were busted and clogging the exaust exit... So I gutted it, just took it out for a spin and punched it, I get this loud whine, like a turbo spoiling up, through all gears, the rpm range on my AFTERMARKET tach shoot up to almost 6000 rpms, it screams.... Car is still "weak", but I have this sound I can't make out, any ideas? Thanks
Re: Whine, whistling, turbo sound???
So.... you are running a gutted cat with no muffler? And it still runs weak?
Hard to say why it might be whsitling. Usually exhaust whistling is indicative of a restriction. Not much left to be restrictive, though. Did you gut BOTH bricks in the cat? Obviously, you got the rear one. Maybe the front one is plugged up as well? Is one of the pipes kinked-up?
A truly hollowed-out cat sounds more like a hollow "rushing" sound, especially with a muffler behind it. Not very pleasing, but not a whistling sound, either.
Car: 91 camaro rs
Transmission: Wc-T5
It def has more power, just not as much as my 92 with the same setup. I gutted the whole cat, front and back... No muffler. Sounds nice actually and when driving normal, as in daily driving, sounds nice runs nice.... But I punched it to see if it had more get up and go, now that its not all blocked up and I get this turbo-ish sound... And it's loud. The only thing I have done to the car, I have mentioned. I don't believe it was doing it before the gutting, although... I reved it once while the full exaust was on and it did make a whine, scared me... So I never did it again, but this is much louder than that.
New2Chevy
09-28-2015 12:35 AM
84 TA NV
09-06-2015 08:02 PM
