Stud girdles for narrow-body rocker arms?
Car: 1985 IROC-Z
Engine: 383
I have some Edelbrock Performer RPM heads with Scorpion narrow-body roller rockers. First question, are stud girdles a good investment? And second, if so can someone recommend some that will work on the narrow body rocker arms? Everything I can find seems to fit a minimum width of 0.600" and the Scorpions are 0.530". Thanks.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Stud girdles for narrow-body rocker arms?
What kind of open spring pressures are you running. Less than 500 pounds and I wouldn't even bother with a stud girdle. I don't even know if those heads use single or double springs. You shouldn't need a stud girdle until you get close to needing triple springs but by then you're getting close to needing shaft rockers instead.
If you have a high spring pressure double spring, upgrading to 7/16" rocker and stud would be better and easier.
Hotrodboba400
12-10-2019 07:07 PM
New2Chevy
09-28-2015 12:35 AM
