seafoam with 93oct?
Car: 1986 t/a
Engine: Lg4 305 carb
Transmission: 700r4 auto
Axle/Gears: 2.73 posi
seafoam with 93oct?
prob a stupid question but im asking it anyways...
my car is an 86 t/a with 150k, its a 305 lg4 auto.
after i fix my starter i want to seafoam the engine. so the question is, would 93 octain help burn better?
Engine: LT1, L98
Transmission: ZF6, ZF6
Axle/Gears: 3.45, 3.31
Re: seafoam with 93oct?
X2^
And since you asked that question, I have to ask this one. What are you trying to accomplish w/the Seafoam? Do you have ANY idea, what is in Seafoam? Do you know which orfice(s) you're going to pour the seafoam into? IOW...is there any science to what you're attempting to do at all?? Or are you simply looking for elixers to pour in your engine to give you a placebo pleasure?
X2^
Engine: LT1, L98
Gasoline and oil both have detergent in them. All oils do and gas, it's mandated by the Govn't. Cheap gas, expensive, low octane or high...it all has detergent in it. So if you change your oil, and you don't use 10 y/o gas, you should really ever need additives to clean those things.
If you feel the need to clean your combustion chambers, use water. It's way cheaper...works as good as anything.
Seafoam = "pale" oil (I think that is <5wt), Naptha, and Isopropyl (SP?) alcohol. It's basically a semi non-destructive concoction that smoke when you burn it so people think it's doing something.
Car: 1986 t/a
seafoam to burn carbon out of my old engine with 150k on it its.
it says right its own website with engine at running temp you pour 1/3 in carb (my case) a 1/3 in the oil and rest in gas tank.. just want to clean out carbon..
i used it this morning it smoked like hell for 10mins and now drives,idles much better
Engine: LT1, L98
Yep. It will do that. Ya spend $10 bux though to do something that a glass of water could have done just as well.
Glad it's running better though!
1 Post
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
Seafoam is great stuff, for anyone that knocks it hasnt used it. At work we used it all the time to fix plugged gunked up carbs and to keep gas in good shape when storing something. Seafoam works.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It works, but it's not magic. It's just camp fuel, paint thinner and rubbing alcohol.
Engine: LT1, L98
^Exactly^. Apeiron "gets it". FtrSpeedy, your work is simply paying way too much for a product it is using to cleans carbs. There are better and much cheaper ways to accomplish the same thing.
Transmission: World Class T-5
Axle/Gears: BW 3.45
I remember when Seafoam cost $2.95 a can. The other 7 bucks is pure marketing. I still use it, though.
Engine: LT1, L98
Someone should start a sticky on ELIXIRS FOR CARS, to help slow the waste of money, and the meaningless pouring of unknown substances into engines etc.
The placebo psychology is strong here.
Seafoam
Marvel Mystery Oil
Slick 50
Restore
Lucas
BG
and on and on....All products that are FANTASTIC at lightening the wallet.
Engine: 383 Carb
Transmission: 4L60
Camp fuel (white gas, lighter fluid, lamp oil, coleman gas, stove oil) is naptha, a petroleum distillate similar to but lighter than kerosene.
Car: 1986 t/a
did what i wanted it to, pulled carb and intake off after and what a difference. for a $5 on sale can i can deal with it car runs and idles awesome now..
HoosierinWA
10-07-2015 10:15 AM
