700r4 to stick
Old 05-10-2012 | 06:37 AM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
700r4 to stick
i want to put a stick in my 84 camaro from an 86 iroc. i got everything but the crossmember and the pedal assembly. is there anything else i need to know before i begin my journey? reason is the 700r4 is shot and i got the stick shift for a steal. also is the torque arm still used on the stick shift trans? and how does that hookup? thanks in advance. any help or pointers are appreciated
Old 05-10-2012 | 07:02 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: 700r4 to stick
There should be an attachment point for the arm on the tail piece of the manual transmission. Yes you will still need to use the torque arm.
Old 05-10-2012 | 03:29 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Re: 700r4 to stick
I believe you can use your crossmember but obviously need the pedals with the switchs. The brake switch can probably be reused but need the clutch switches. Did you get the hydraulics, master/ slave cylinders? The Torque arm mount is a compression type that is bolted to the tailshaft of the transmission and is different from the 700r4 setup. Your old driveshaft might still work. If you did not get the center console shift plate and inner and outer boots then you will need to look for one or mod your auto shift plate and get shift boots.
After that you swap the trans you will need to wire the clutch start safety swtch and reverse lights.
Old 05-10-2012 | 07:18 PM
adamemerson's Avatar
Car: 96 Z28 & 89 RS
Engine: Lt1 & 383 Stroker
Transmission: 4l60e & t5-5speed
Re: 700r4 to stick
I did the swap on my car your drive shaft will work and you tq arm mount will work i never wierd up a clutch safety switch tho it dont realy matter ( i know to push the clutch when starting it)
Old 05-11-2012 | 10:24 AM
Engine: 355
Re: 700r4 to stick
do i need the complete pedal set or can i just install a floor mount pedal/hanging type pedal? and what switches are on the pedal?
Old 05-11-2012 | 10:37 AM
Engine: 355
Re: 700r4 to stick
also do i need a new starter?
Old 05-13-2012 | 11:43 PM
rockstarr4's Avatar
Car: '84 Camaro - 2010 Surf Blue
Engine: 305 - 4 bbl Holley
Transmission: WC T5
Axle/Gears: 3.08
Re: 700r4 to stick
I did this swap 1-1/2 yrs ago and I'd do it over again in a heart beat. I recommend that you stick with the pedal assembly designed for this car. It attaches primarily to the 4 bolts of the brake power boster (plus some additional supports) through the firewall. If you try to use some other type of pedal assembly that mounts somewhere else to the firewall, I would almost guarantee that it will flex under pedal pressure as very thin sheet metal is used everywhere in this car.
As far as the starter, I did have to buy a different one specific for a manual transmission. I bought mine at my local NAPA.
Here are the step by step instructions that I used: http://www.fbodymotorsports.com/thirdgen5spdconversion. Read this over several times and make a parts list. Don't start until you have everything they mention.
Old 05-15-2012 | 01:12 PM
Engine: 355
Re: 700r4 to stick
where can i find a pedal set at? its a joke trying to find em at a junkyard. also am i able to use a universal pedal regardless of mount issues? and is a floor mount one possible?
Old 05-15-2012 | 01:26 PM
rockstarr4's Avatar
Transmission: WC T5
Axle/Gears: 3.08
Re: 700r4 to stick
Here's a source for the pedal assembly: http://www.hawksthirdgenparts.com/ca...semblynew.aspx
Old 05-24-2012 | 10:00 AM
Engine: 355
Re: 700r4 to stick
has anyone used non camaro pedals? im having a rougbh time paying 150 for a used set of pedals. also can my stock starter work or do i have to get the smaller starter. and lastly, i need to find the speedometer housing that goes in the trans. anyone know wherer to find theses?
Old 05-24-2012 | 02:13 PM
91phoenix's Avatar
Re: 700r4 to stick
As far as I know everyone uses stock pedals. Are you putting in a T5 or a T56 6 sp transmission? If a T5 and you can not find any try an ad in the parts wanted section here. If a T56 look at the 93-97 Camaro and Firebirds also. I haven't checked for certain but you might even be able to make the 5 sp pedals from these years work.
Old 05-27-2012 | 08:27 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Re: 700r4 to stick
Just search the junkyards for the pedals that fits our cars only. Drive shaft and torque arm will work fine with no problems and both mounts the same as the auto. Use all factory assembly parts. Keep it simple!
Old 05-29-2012 | 07:39 PM
Engine: 355
Re: 700r4 to stick
does anyone have a pic or 2 of where i need to cut the hole, and how big?and also a pic of the trans bolted up to the crossmember? thanks
Old 05-30-2012 | 02:02 AM
rockstarr4's Avatar
Transmission: WC T5
Axle/Gears: 3.08
Re: 700r4 to stick
Here are a couple of photos I took during my T5 swap. Sorry, I don't have one of the clutch master cylinder hole. Hope this helps.
Attached Thumbnails 700r4 to stick-0127012159.jpg   700r4 to stick-0127012156.jpg
Old 05-30-2012 | 07:30 PM
Engine: 355
Re: 700r4 to stick
perfect! thank u. also did u use a 700r4 starter or did u buy a smaller one?
Old 05-30-2012 | 07:46 PM
rockstarr4's Avatar
Transmission: WC T5
Axle/Gears: 3.08
Re: 700r4 to stick
No, I couldn't use the original starter, it didn't fit into the bellhousing opening. The T5 flywheel is smaller (153 tooth) and you need to use a starter spec'd for this. I got one off the parts car that provided the tranny, bellhousing & pedals. I then replaced it a year later with a reman unit from NAPA.
Old 05-31-2012 | 02:22 PM
91phoenix's Avatar
Re: 700r4 to stick
You do not need to cut the hole that big. That is probably close to the factory opening though. You only need about 1/2 to 3/4 inch around where the shifter bolts on. His pics are great to give a general location though.
Old 05-31-2012 | 07:00 PM
rockstarr4's Avatar
Transmission: WC T5
Axle/Gears: 3.08
Re: 700r4 to stick
Yes, you are quite right; don't go as forward as I did. I barely had metal left for the sheet metal screws on the front end of the inner shifter boot.
Old 05-31-2012 | 07:34 PM
Engine: 355
Re: 700r4 to stick
any idea how far forwrd and back i should go? i dont wanna go tofar and have a gapping hole
Old 06-02-2012 | 06:00 PM
Engine: 355
Re: 700r4 to stick
i got the shifter today and mounted it and the gear shifter wont moveinto any gears. the trans is ona bench would that matter why it wont shift? i opened it up and gears look like new and no metal. any ideas?
Old 06-02-2012 | 11:29 PM
rockstarr4's Avatar
Transmission: WC T5
Axle/Gears: 3.08
Re: 700r4 to stick
The attached photo shows some dimensions for the tranny hole. The 3" dimension starts where the metal starts to bend up to a higher elevation.
Regarding the static shifting, have you tried to turn the input shaft by hand a little bit? This might help line up the syncros better to engage the gears.
Old 06-03-2012 | 10:06 AM
Engine: 355
Re: 700r4 to stick
so thts my issue is that the gears arent lined up? it moves back and forth but wont engage in any gears
Old 06-04-2012 | 10:07 AM
91phoenix's Avatar
Re: 700r4 to stick
It is entirely possible and definitely worth the try. I would have expected it to shift into one gear though. Also I have found that it helps alot if all the gears inside the tranny have a thin film of oil on them to help everything slide easier.
Let us know.
loud91rs
10-05-2015 10:05 PM
92projectcamaro
09-29-2015 07:07 PM
IROC ZELLER
09-29-2015 03:00 PM
indygene
09-26-2015 11:21 AM
6998poncho
09-25-2015 02:56 PM
Quick Reply: 700r4 to stick
