Ground wires getting hot and melting! Please help :/
Okay guys, here is the problem. My ground wire coming from the firewall to the block is getting hot and burning. I have it bolted down to the chrome distributor hold down could that be the problem? also the small black ground running from the negative battery cable to the fender is getting hot and melting. I can't figure it out Someone please help. I had to lengthen the starter wires to get them away from the headers, could I have one of them wires ran wrong?? Just please someone help me :/
Car: check
Engine: check
Transmission: check
Re: Ground wires getting hot and melting! Please help :/
RBob.
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
sounds like the negative battery cable is not making
good connection to the block,forcing the current to
go through the body grounds(they are only getting hot
during cranking right?)
Engine: 4++,350 & 305 CIs
Yes. the big cable should go to the head or alt or starter bolt.
the little wire on back of your motor also needs to be to the head and firewall.
Thanks for all your help guys. My Big neg. battery cable was not getting a good enounh connection on the alt. bracket. Plus there were 4 layers of paint on it!
eightsixseven
08-14-2015 03:09 PM
