help identifying a old cam
i baught a old crower cam for $15 its stamped crower 3067 in the back. i did some research and the closest i got was 03067 and its the v6 cam but mine has 16 lobes so its definetly for a small block and i did some more research and found a guy looking for a 80s cam spec's and called and crower said they lost there records in a fire and another said he called and they said they don't keep records further than 15 yrs. anyone recognize this v8 part number crower 3067? ill post a pic later
Car: 1983 Z28
Engine: Forged 355
Re: help identifying a old cam
Does it say CNC anywhere on the cam? And that's a flat tappet cam.
Also, welcome to TGO!
Received 1,839 Likes
Doesn't look like it matters much at this point unless you're starting up a "rusted industrial object" museum.
$15 down the drain. I hope you bought it before you saw it?
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
besides the major cleanup that will be needed with that
cam,a flat-tappet cam that has run long enough to have
"broken in"will be risky to use with new lifters-lifters
and cam lobes wear to a specific pattern when they
"break in"and if new ones are installed and run on a
broken in cam,rapid wear and oil contamination with
metal particles is the usual result.
Car: 1983 Z28
Engine: Forged 355
It cleaned up really well! If it doesn't workout summit has a line of cams for around $75, or cam and lifters for $100. And fwiw, that looks like a new cam compared to the one I pulled out of mine.
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Might be clean but doesn't mean it should be used. That cam is wiped out - the 3rd lobe from the front of the pic is rounded off - see how it's not as 'pointy' as the others. Use it to go beat the guy over the head.
