Main and rod bearings
Car: 89 IROC Z/88 IROC Vert
Engine: 350c.i./305c.i.
Transmission: 700R4/T-56
Axle/Gears: 3.42/4.10
Hey guys, I'm replacing the bearings in my 350. Stock range on the mains are 2.4484-2.4493. Mine came out to be 2.4475. Stock range on the rods are 2.099-2.100. Mine are 2.097. My question is what size bearings do i need? Are these numbers close enough to just order stock size replacements? Thanks in advance.
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Main and rod bearings
The last time I did one like that the machinist told me to use 2thousants over size bearings. You should go in and talk to your local machinist and see what he says.
I called up Fel-pro and they really went above and beyond to help me figure out what sizes i needed. Great people in their tech department. Thanks everyone.
[ON] 9 Bolt Axles Partout
6speedIROC
16
03-15-2023 08:33 PM
