Is there anyway to tell a 305 from a 350?
Old 03-22-2012 | 03:12 PM
mustangdmurder's Avatar
Car: 1982 Z28
Engine: three 350s, all casting #370010
Is there anyway to tell a 305 from a 350 with out pulling the engine out of the car?
Old 03-22-2012 | 03:13 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
Re: Is there anyway to tell a 305 from a 350?
Pull the heads off and measure the bore.
Old 03-22-2012 | 03:15 PM
Car: 1982 Z28
I thought that too but I don't want to get any dirt or dust in there. My garage isn't the cleanest in the world.
Old 03-22-2012 | 03:30 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Check the casting numbers on the block.
Old 03-22-2012 | 03:40 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
On the back of the block right below the head on the drivers side it will say either 5.0 or 5.7. Your going to need to move some wires and maybe even use a mirror to see it. Its going to be in the area between the firewall and the engine.
Old 03-22-2012 | 03:49 PM
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
throw it in the water see how long it takes to sink then get a LS they have fancy stamps on the back that say exact size
Old 03-22-2012 | 03:54 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Not on an older block, but it will have a casting number in the same spot.
Old 03-22-2012 | 04:05 PM
Car: 1982 Z28
I didn't see any numbers back there so I was trying to see if I could feel some and its smooth.
Old 03-22-2012 | 04:07 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
They're back there. Top surface of the block behind the head.
Old 03-22-2012 | 04:20 PM
Car: 1982 Z28
I don't see them anywhere here I stuck my camera back there and took some pictures
Old 03-22-2012 | 04:28 PM
lunati397's Avatar
mouse turds
Old 03-22-2012 | 04:29 PM
lunati397's Avatar
have you run the vin number or checked the RPO codes in the glove box in the trunk
what model year and TPI carb ect
Old 03-22-2012 | 04:32 PM
Car: 1982 Z28
I checked the vin and it should be a 305 but it had some aftermarket parts in it which leads me to believe it may not be a 305.
Old 03-22-2012 | 04:37 PM
lunati397's Avatar
350 and 305 parts are the same so it is most likley a 305 some guys like to mod 305s because you can get higher RPMS out of them and spin them all day long
what aftermarket parts are on it
If its a 305 it will be tbi with auto or standard but it can be a z28 with TPI then if it is auto its a 350 if its a standard its a 305
Old 03-22-2012 | 04:38 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Try cleaning up the area with some solvent and a wire brush to see if you can find numbers under the caked-on crud.
Old 03-22-2012 | 04:40 PM
Car: 1982 Z28
Its got a carb and a manual transmission. I am not sure of all the aftermarket parts include as far as I know, elderbrock valve covers, cowl induction hood, GT grant steering wheel, Hurst shifter, than a sound system.
Old 03-22-2012 | 04:41 PM
Car: 1982 Z28
I am on it.
Old 03-22-2012 | 04:43 PM
lunati397's Avatar
all signs point towards 305 unless its not the original motor and judging by the grime it looks like it is
Old 03-22-2012 | 04:44 PM
Car: 1982 Z28
But the orange paint on the oil pan makes me nervous
Old 03-22-2012 | 04:56 PM
Car: 1982 Z28
Cleaned it off some and took another pic and GOT THE BLOCK NUMBER!!!!!!!
Old 03-22-2012 | 05:15 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Congratulations, it's a 4" bore.
Old 03-22-2012 | 05:16 PM
Car: 1982 Z28
It has a dang 350. First my 307 turned out to be a 350, now my 305 what the same heck?
Old 03-22-2012 | 05:23 PM
Car: 1982 Z28
Thanks for the help guys.
Old 03-22-2012 | 05:30 PM
subroc's Avatar
Engine: 355 TPI
010 block. Thats a 70s era block and a 2 piece rms. I have one in my 88 too (i put it there lol). Its most 'likely' a truck motor that someone put in there thinking it was going to be faster. If it has stock truck heads on it though its probably slower than the 305 that it replaced. It is however a very good starting point for a performance build.
Old 03-22-2012 | 05:32 PM
Car: 1982 Z28
Yeah I have two of them now. haha
Old 04-27-2012 | 01:00 PM
Car: 1982 Z28
Hey does anyone know a way to tell a 2 bolt main from a 4 bolt main with out taking off the oil pan? I ran the casting number on the block 3970010 and it says for the 350 it could be either one. The head castings are 3998993. So I know its a 350 truck motor from 68-72. So does anyone know if it would be a 4 bolt or a 2 bolt main?
Old 04-27-2012 | 02:06 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Without taking the pan off there's absolutely no way to know. Fortunately there's little reason to care.
Old 04-27-2012 | 02:22 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Assuming those anchors errr heads are the originals then I think it is a 2 bolt. Most of the 4 bolts got 1.94 valve heads like 333882s.
Not really a big deal. Toss the heads out and put something better on there and wake it up a bit.
Old 04-27-2012 | 02:36 PM
Street Lethal's Avatar
Yes, floor it, you'll know soon enough...
Old 04-27-2012 | 02:57 PM
Car: 1982 Z28
Sure there is. If its are 4 bolt I can take it to a lot higher RPMs.
Old 04-27-2012 | 02:58 PM
Car: 1982 Z28
Haha Actually after finding things out about my 350 I believe a stock 305 would be faster.
Old 04-27-2012 | 02:59 PM
Car: 1982 Z28
I agreed these heads are pretty much worthless, but luckily switching heads isn't that big of a deal.
Old 04-27-2012 | 03:01 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No. In the list of things that affect high-rpm operation, the number of bolts that happen to be holding the stationary main caps on is dead last.
Old 04-27-2012 | 03:06 PM
Car: 1982 Z28
No a 2 bolt main is at risk if you push over 6000RPMs, but a 4 bolt you can push 7500RPM and be great.
Old 04-27-2012 | 03:14 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Who told you that nonsense?
Factory 4 bolt mains are most common in highly-loaded, low-rpm truck engines. What does that suggest about their design intention?
Old 04-27-2012 | 03:22 PM
Car: 1982 Z28
I just read about a guy with a 327 2 bolt main that tore apart at 6500RPM. Think about 2 versus 4, the 4 bolt has double the strength.
Old 04-27-2012 | 03:28 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
What about the 4 bolt 305 that tore apart at 4500 RPM? Or the 2 bolt 383 that lives at 7000 RPM?
A 4 bolt main has double the number of bolts, not double the strength.
Old 04-27-2012 | 03:30 PM
Car: 1982 Z28
4 bolt 305? I have never heard of a 4 bolt 305 before.
Old 04-27-2012 | 03:36 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Some low-performance 305 truck engines built in Canada were 4 bolt main. The "high-performance" 305s in cars didn't.
Old 04-27-2012 | 03:41 PM
Car: 1982 Z28
I still highly doubt that a 4 bolt 305 ripped apart at 4500RPM. Unless it was pushing 1000HP and over 750 pounds of torque
Old 04-27-2012 | 05:04 PM
I still highly doubt that a 4 bolt 305 ripped apart at 4500RPM...
Like Apeiron said, 4-bolt mains have double the amount of bolts, not double the amount of strength, the strength is in the casting. Exactly how much power do you think the factory main caps and bolts can withstand...?
Old 04-27-2012 | 05:20 PM
  #42
Car: 1982 Z28
I would personally have a 2 bolt main go to 5500RPMs and a 4 bolt main go to 7000RPMs.
Old 04-27-2012 | 08:00 PM
  #43
Delia38's Avatar
Old 04-28-2012 | 12:34 AM
  #44
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
What's stronger, something with 2 holes drilled in it, or something with 4 holes drilled in it? Doesn't matter though, RPM isn't what splits blocks.
At the end of the day there's no appreciable difference in strength between factory 2 bolt and 4 bolt mains on the same casting, especially in pretty much any build that could be considered streetable.
If you had an application where you really had reason to be concerned for the strength of the mains, and you were convinced you had to stay in a stock block, you definitely would not use a 4 bolt main block. You'd use a 2 bolt block, because you can drill it for splayed steel caps, which are stronger.
Old 04-28-2012 | 09:03 AM
  #45
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Too early for '882 heads, and the 4-bolt blocks were either 'vette or pickups heavier than half-ton. As such, the 4-bolt blocks got either the 2.02" valves for 'vettes, as not all 'vettes got the 4-bolt. LT1 / L82 did, L48 / LM1 were 2-bolt with 1.94". Trucks heavier than 1/2-ton typically got 1.72" intake valves. and not all '993 heads came with 1.72s. Very few 4-bolt blocks got 1.94" intake valves, if any. GM practice rarely stands to hot-rod reason.
Old 04-28-2012 | 02:52 PM
  #46
Car: 1982 Z28
So you're saying that there is a good chance my block is a 4 bolt main?
Old 04-28-2012 | 02:54 PM
  #47
Car: 1982 Z28
I am not talking about the block splitting cause they are the exact same thing besides the caps. I am talking about the caps coming off. And I agree that if I were to be pushing ridiculous RPMs that you would go with a 2 bolt main and drill it for splayed steel cars.
Old 04-28-2012 | 06:24 PM
  #48
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Anybody that plans to build big horsepower wants a 2 bolt block instead of 4 so that he can add splayed aftermarket caps. That configuration is much stronger than a factory 4 bolt setup.
But even that has nothing to do with high rpm capability. 2 bolt, 4 bolt or splayed, it's got nothing at all to do with rpm capability. Your valvetrain, rods & rod bolts and crank all have infinitely more to do with safe high rpm capability.
Old 04-28-2012 | 06:45 PM
  #49
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
600 hp (with the 75 shot) and 7100 rpm with the 2-bolt stock bottom in my Impala, no problems after 2 seasons of racing it.
My buddy's 2-bolt main 383 spinning to 7100 rpm DID exhibit some main cap "walk" when he rebuilt it after racing it for 3 seasons. He's 4-bolt splayed now.
Old 04-28-2012 | 07:06 PM
  #50
Jim85IROC's Avatar
The longer stroke multiplies the forces exerted on the crank & caps. Horsepower + longer stroke = cap walk.
Quick Reply: Is there anyway to tell a 305 from a 350?
