Difference between Saginaw and Saginaw P Series?
Car: 1985 IROC-Z
Engine: 383
I want to buy a new power steering pump, not sure what our cars have or what the difference is (my car is a 1985 Camaro IROC-Z, but I'm putting a whole new motor in it).
If I'm replacing the pump with a setup that comes with brackets, does it even matter which one I get?
Car: 92' Camaro RS
Engine: 383 Stroker
Transmission: M5
Re: Difference between Saginaw and Saginaw P Series?
The P series typically uses a keyway, bolt on pulley. where as the siginaw uses a press fit pulley. Also the P series depending on which one you purchase can be used with a remote reservoir rather than the one attached to the pump.
Car: 1985 IROC-Z
Engine: 383
Okay, thanks. That's good to know since I'm probably going to be buying a pump and then switching out the pulley.
Hotrodboba400
12-10-2019 07:07 PM
