starts in morning 3 or 4 starts then won't till morning
Old 03-02-2012 | 08:06 PM
DEBONOCEAN's Avatar
Car: "87" Z-28
87 camaro - starts in morning, I was getting 4 or 6 starts (now 2 times)then it leaves me stranded. Won't start till morning. New carb, battery, and starter.
I've talked to guys got them all stumped. runs great when it starts LOL...
Please help (guess i'm losing weight walking home lol)
Old 03-02-2012 | 08:27 PM
Fritomaster's Avatar
Car: 1991 RS
Engine: Stock 305
Transmission: Stock
Axle/Gears: Stock
Re: starts in morning 3 or 4 starts then won't till morning
Wierd man...... >.> I dont know enough to help though sorry :X
Old 03-03-2012 | 12:43 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Need more information, - as much as possible.
When it doesn't start what exactly does it do?
What are the indications?
Does the starter spin the engine over but no cylinders firing?
Does starter do nothing? Is there a click or clicks?
Does starter turn but very slowly?
Old 03-03-2012 | 01:53 AM
cphgncowboy's Avatar
Car: 1991 Formula
maybe fuel pump i always thought they went out in 2 ways either they went out or started leaking(mechanical) until this happened to me
car would start and run fine for awhile and then dieand not start until the next day(or until it sat a few hours always waited til next day) what was happening is after it sat it would build back up the psi it needed and after it ran awhile would lose it and not start back til pressure built back up
i'd check into that
Old 03-03-2012 | 08:27 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
i'd check into that
problem with your theory is fuel pumps don't build up pressure by sitting over night.
Old 03-03-2012 | 02:54 PM
DEBONOCEAN's Avatar
Car: "87" Z-28
Thanks for replying... It fires right up in morning and runs great, after a couple of starts, it won't start till next morning. Acts like it wants to start, then smells like it's flooded without pushing gas pedal. New carb nov 2011, battery feb 2012, starter replaced last thursday (started to make starter noise so I replaced -11 yrs. old) Fired up 5 times in garage afterwards, drove to store, wouldn't start till morning, then started just fine, Sooo those were not the problem Maybe LOL.. I'am now checking for loose ground, bad wires. Wire getting hot??? Soooooooo stumped also could it be key switch?
Old 03-03-2012 | 02:56 PM
DEBONOCEAN's Avatar
Car: "87" Z-28
oh sorry also could it be key switch?
Old 03-03-2012 | 05:37 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Take the ignition module out of the distributor and get it checked. They start failing when they heat up and sometimes will work after cooling off
Old 03-03-2012 | 06:10 PM
rrf321's Avatar
Car: 91 formula
Engine: 5.7 not o.e.
Axle/Gears: 273 2 wheel drive
how about next time it doesn't start , try dumping a little gas in the carb to see if it is a fuel problem.
Old 03-05-2012 | 03:13 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
+1
Old 03-07-2012 | 03:36 PM
DEBONOCEAN's Avatar
Car: "87" Z-28
Thanks guys i'll try module
Azrael91966669
25
06-20-2017 05:04 AM
Orr89RocZ
04-25-2016 09:28 AM
Wade787b
09-29-2015 02:15 PM
transamgta1Khp
08-17-2015 01:18 PM
apie2546
08-10-2015 06:43 PM
