EGR Blockoff/ Vacuum Lines
Old 02-20-2012 | 11:31 PM
jlex300's Avatar
Car: 1987 IrocZ28 350
I have been searching this and numerous other sites trying to find a complete guide , preferably with some pictures on how to delete the EGR. I am not worried about emmisions or passing inspection so dont even bother making any of those comments. I already ordered a block off plate from JEGS. But Im confused about the vacuum lines running in and out of the EGR valve , also there is a wire coming out of the old EGR that looks like some type of sensor that plugs into something behind the distributor. Also the hook up to the selonoid. I also read somewhere you need to change the chip or reprogram it so you dont get a check engine light. How is this done? Any help would be appreciated. Im posting some pics so you guys can see what Im working with. Im really trying to clean up the bay and reroute or gid rid of unnecessary hoses and wires. I have also got rid of the smog pump and all the crap on the passenger side. It is not a daily driver and is being set up as more of a cruise night/show car so to speak.
Well here are the pics. thanks
EGR Blockoff/ Vacuum Lines-5.jpg
EGR Blockoff/ Vacuum Lines-6.jpg
EGR Blockoff/ Vacuum Lines-7.jpg
Old 02-21-2012 | 01:08 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: EGR Blockoff/ Vacuum Lines
Originally Posted by jlex300
[SIZE=3] Im confused about the vacuum lines running in and out of the EGR valve ,
Remove all vac lines and plug where the line originates
Remove EGR solenoid and valve
remove sensor ; make all wires safe
some type of sensor
You need a custom chip with the EGR deleted to replace your stock one in the computer
83 Crossfire TA
01-03-2016 02:26 PM
86CamaroDan
09-29-2015 11:08 PM
64goatman
09-09-2015 02:09 PM
IROCtometal
09-09-2015 11:01 AM
TBRays98
09-06-2015 06:05 PM
