vavles rattling when i accelerate?helphelp
Car: 90 iroc z
Transmission: 4 speed with od
Axle/Gears: 323 ratio
90 iroc z with 350.when I push on it"vavles rattle n knock even when I run high octane fuel!it runs fine but when I wanna speed up real quick it starts rattling n valve springs.also engine light comes on after a couple miles! Just bought car n ot looks stock except for air intake!what should I try??
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
Re: vavles rattling when i accelerate?helphelp
EGR? Sounds also like timing could be off?
I would start with timing first. That should be free if you have a timing light. Do you?
YES!!! What is your setup? TBI, TPI carb? 350, 305, v6? You will need to do a search and find out on the site on what the timing calls for. I have a TPI and I have to disconnect a single wire up by the blower unit by firewall and set mine at 6 degrees retard.
Your should be different but I do not have the specs, someone else sure wil or chime in after you post what your confirguration is.
Car: 90 iroc z
All I know it is a 350 tuned port injection!does that help"I'm really lost wit camaros .this is the 1st car I've ever owned lol!I was a pickup truck guy b4.but always love the irocs"so I'm kinda new 2 this lol
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Do you have a timing light?
Disconnect the ESC plug (The trucks have this too) and then loosen the distributor hold-down bolt and set the timing to 6 degrees. Tighten bolt. Turn off. reconnect ESC. Continue with your life.
okay - so TPI (Tuned Post Injection), 5.7 = 350. So there will be a little cover on the back of the TPI with three small bolts, You will remove that cover using a Torx T15 driver. You then will move toward the passenger side and find a SINGLE wire that sits on top of the blower (usually) with BROWN and I think black stripe. Disconnect it, it will have a plug. Make sure the nut on the distributor is loosened - not LOOSE - just enough where you can trun the distributor with a little effort, you don't want it to be so loose the engine will turn it itself.... IN order to loosen this bolt a distributor wrench sure makes it easier with the curvature. The wrench in a 9/16".
You will then hook up the timing light (make sure all wires and going to get into the engine) and see what your timing is at... I am thinking it is off quite a bit. You will see the tab when your positioned on the drivers side of the car low on the harmonic balancer (Crankshaft pulley) . Set it to 6 degrees retard by turning the distributor with engine running - some say you can go to 10 degrees retard but I think that causes other internal issue and excess wear on engine. Retard is couterclockwise off the tab (not sure how much you've worked on cars).
Once set - turn off car. Tighten distributor bolt - reconnect brown wire and put back on TPI/distributor cover. Test it and see what you have!
Car: 90 iroc z
Awsome thks"? Tho lol I feel so dumb n probaly are but wat is a esc plug n were would be?thks fellar
I think the only item I missed is: once all set, turn off car - disconnect battery cable for a few minutes. Reconnect (this will reset computer) and go for a ride.
Car: 90 iroc z
Well this is weird"got n the car wen I got off work an it ran like a champ!no engine lite cmes on r nutting"what's yur opioion on this now??
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
You may need a distributor wrench to get to the hold down bolt on the distributor. Also, may be easier to remove the coil if it is a tpi car. Don't forget to bolt it back down after you tighten the distributor bolt back up though. Then adjust the timing.
Pac J
05-17-2020 10:44 AM
RedLeader289
05-28-2019 01:47 PM
