Engine Running Hot?
Car: '89 IROC-Z
Engine: 5.7L TPI
Engine Running Hot?
1989 IROC-Z
5.7L
700R4
Dual fan
Alright, I've been researching this issue for the last hour or so and I've yet to draw anything conclusive.
Ever since the heater core replacement was completed, the car has been running hot. At stop lights and even in traffic, the heat would start to blow cold and the engine would rapidly overheat. After idling it with the radiator cap off and filling it in an effort to get the air out of the system, I have yet to have that problem again.
It now just seems like it runs way, way too hot. The left fan doesn't come on until 240~ degrees and the right fan doesn't come on at all, even if the A/C on (it's not charged, if that makes a difference.) From what I understand, the two fans are independent of one another and the right one shouldn't affect the operation of the left.
From a couple of things I've read, people say it's normal for the engine to get this hot before the fan comes on but this doesn't seem right. I know it was designed to run hot but I'd like to make sure before I put my mind at ease about it.
Any help you guys can offer is greatly appreciated.
5.7L
700R4
Dual fan
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Engine Running Hot?
Have you checked gauge is actually reading correct engine temp?
What temp ( indicated ) does engine come down to after fan runs?
Is engine using coolant?
There is no gas in the A/c system to operate the pressure switch that signals the fan to run
Car: '89 IROC-Z
Engine: 5.7L TPI
I have not checked the accuracy of the gauge but it has been reading correctly (to my knowledge) until this point. I don't have an infrared thermometer, are there alternatives?
Engine comes down to about 220 before the fan shuts down again.
Yes? I don't have a reason to believe it isn't?
Car: 82 Z28
Transmission: T400
Car: '89 IROC-Z
Engine: 5.7L TPI
This is my first cooling system issue so it's been touch and go.
Car: 82 Z28
Transmission: T400
Run engine at revs ;2000 + ( should see coolant level drop in radiator )
Pour coolant in while holding revs up , replace cap before letting off revs.
Car: '89 IROC-Z
Engine: 5.7L TPI
Tried it and I can't do that, coolant level doesn't go down, it just spits it back out the top of the radiator and onto the battery. Which creates a cavity and more air gets sucked in. What am I missing here?
theshackle
03-05-2017 06:37 PM
