crossover touching oil pan
put 3.4 block swap in place of a 3.1.in a 90 bird.now moved motor to a 90 rs.This time I noticed the crossover is touching the oil pan.Same set up.motor, crossover,tranny.just different body.the bird got rearended(totaled)I'm sure this cant be good.The bird was only drove short runs of 10 to 15 miles at a time for the most part.how big a deal is this?
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: crossover touching oil pan
Whats touching, the exhaust y-pipe cross-over, or the front k-member that supports the engine/front suspention?
the exsaust y pipe right behind the k-member.there is a space between the oil pan and k-member that the y pipe is suposed to pass through.I'm sure it isn't supposed to touch anything. I'm planning on replacing the whole mess after it's together and running.I think it's just been pieced together.There's welded seams all over.About 5.Where can I get a factory spec one?
Car: 88 Camaro SC
Engine: SFI'd 350
Probably your best bet is to get a new aftermarket exhaust system or OEM factory style y-pipe. If you just want it to work companies like Walker make cheap replacement exhaust components.
Edit: this is pretty typical of what youd need to pay http://shop.advanceautoparts.com/web...R%7CGRPEXHAAMS_____
Car: 88 Camaro SC
Engine: SFI'd 350
Theres also the junk yard as well. But if it where me, Id look at spending a little more on a good aftermarket system. You did all that work for the 3.4L, might as well get the extra benefits rather than choke it with the factory stuff.
