Spark plug wire separators?
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
What do you guys use? I want my plug wires to run along the top of my valve cover. Not really having luck finding what I want. Suggestions?
I want to prevent my wires from rubbing anything + crossfire.
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Spark plug wire separators?
zip ties...seriously. saw an awesome trick with zip ties a few years back and ill never buy another set of wire seperators.
they do make wire seperators that bolt to the valve covers too if you want them to look pretty.
Engine: 4++,350 & 305 CIs
I use zip ties also. NASCAR style..
Yeap, one big zip tie around them all, snug lightly.
Then between each wire place another zip tie to seperate them.
Slowly tighten them to keep a nice flat fit.
I'd go alittle tighter then the picture shows.
Car: 91 Camaro RS
if you tuck the tie part on the bottom, it looks cleaner.
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
ck.out "made4you" at summit or jegs . i have them and really like them . good luck .
I want them on the valve covers so they do not rub against my brake lines or steering column. It's the driver side I care about, too much emissions stuff on the pass. side to bother.
your welcome , i have the blue ones with red MSD 8.5mm wires . looks great on polished alum. valve covers . i also cut/made each wire custom to lay & route neat looking . good luck .
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Zipties here as well. I have to since header clearance is horrible.
Long live the zipties.
1 Post
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
zip ties as well its great and very cheap! billet specailties has some wire looms ( which I have and never used )might want to check out there site
1 Post
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
I run a Moroso setup and am completely happy with them. Pictures are in my signature, second page, toward the end.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Russell # 611147
They come with more wire holders ( a 3 and a 1 hole ) but I got the best angle around my headers to the plugs by only using two
Had to find these days ( N/A at Summit ) but SDparts have them listed as available
http://sdparts.com/details/russell-p...ucts/rus611147
1992 Trans Am
05-10-2023 07:19 PM
eightsixseven
08-14-2015 03:09 PM
