squeaking noise comming from hatch
Car: 1987 camaro Z28
Engine: 5.0 TPI LB9
Transmission: 700r4 auto
Axle/Gears: 2.62:1
i have this weird squeaking m=noise coming from the hatch area of my 92 camaro rs when i turn. You kno like when the weight shifts it squeaks like crazii
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: squeaking noise comming from hatch
Is it really coming from the hatch, or just that general area?
Assuming it is, the body flex is the core problem, but silicone oil on the rear hatch weather stripping and/or some grease on the hatch hook/mechanism can help quiet it down.
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
Get down and look at where your exhaust brackets are welded to the "frame." I bet you see cracks in the welds.
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
mine does the same thing when i hit big bumps. but thats because i have my hatch temp rigged as a slam hatch since the hatch motor has gone out.. could just be the hatch is loose and needs some adjusting.
theshackle
09-17-2020 08:26 AM
