Intake Manafold
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Intake Manafold
Are the 305 and the 350 TPI intake manifolds the same.
Re: Intake Manafold
Identical. Just the above-mentioned differences between the 86-down and 87-up manifolds in bolt pattern. Also, I don't recall when they did away with the 9th injector, but I think the lower intake might be different on earlier engines that used a 9th injector vs. later ones that didn't. I'm sure somebody will chime in and clear up the 9th injector issue shortly.
jerflash
09-24-2015 03:11 PM
toronto formula
09-10-2015 07:31 AM
e3pres
09-09-2015 01:51 PM
