Fitting at Mechanical Fuel Pump Leaking
Back story: Tired to replace the fitting and line with AN/braided line. Broke the AN fuel pump fitting. Used a NPT fitting as a stop gap; the inverted flare was a bit smaller.
Replaced that with Edelmann 721660 3/8" Tube x 3/8" inverted flare. Though I believe the fitting is tight, it weeps a bit while the car's running (nothing on the fitting or garage floor this a.m.).
Would I be better off using Dorman 785-408 3/8" inverted flare with a bit of thread sealer (the resistant to gasoline type)?
Or is there a better alternative? If so, I'm all ears.
One final question, could I have somehow mangled the pump flare, which is causing the leak?
JamesC
JamesC
Re: Fitting at Mechanical Fuel Pump Leaking
No mismatch. As the Edelmann has a tube running through the nut (like OE), I doubt that a sealant would be of help. The Dorman, however, is rigid. A sealant might be useful there. With Thanksgiving behind me, I may crawl under today and see what's what.
JamesC
JamesC
theshackle
03-05-2017 06:37 PM
R3500
08-17-2015 12:16 PM
