wont crank
Car: 87 Iroc
Engine: 350 from a 69
wont crank
84 z28 305 H.O.....car drove then after parked and turnd off, now the car wont even crank, when i turn the key to on nothing happens at all no gauges, radio, windows are down and cant get them up, no nothing, the headlights come on when i turn them on but thats it...and BATTERY is GOOD reads 12.7 volts. receently repalced the starter. my brother was the one who pulled the starter like 3 months ago (its his car) i put the starter in today. pretty sure i hooked it up right, the 2 big cables on b+ terminal and the little wire on the S terminal, nothing on the R terminal...i checked for power going to the starter its reading 12 v at the starter, also had the starter checked and its good. so the fact theres no power in the car im thinking maybe the ignition switch?? if so how do i check it with a volt meter, thanks
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: wont crank
check the battery cables-on some battery cables the
strands are aluminum and can corrode and break
connection when disturbed...
Car: 87 Iroc
Re: wont crank
ya i cut the insulation in the middle from bat to starter was good read 12.6 and then i checked for power at the starter to double check was good read 12.6 thanks tho
Car: 84 camaro
Engine: 2.8
Transmission: 5 speed manual
Re: wont crank
it sounds like an ignition issue to me, what id do is pull the ignition and start checking wires to see if any of them are getting power. maybe it is something silly like a fuse
Re: wont crank
skinny z
10-05-2015 06:23 PM
