IAT SENSOR!!
IAT SENSOR!!
I have a 87 chevy camaro with a 350 and the iat sensor is no where to be found so i want to know where the wiring harness comes from so i could just reinstall because ive looked everywhere for it already and cant find it!
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Re: IAT SENSOR!!
If it is a 350 TPI the IAT sensor is underneath the back of the plenum. The wiring connector that goes to it comes from the main harness behind the motor.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: IAT SENSOR!!
It is "upside down" up into the bottom of the plenum. With some long nosed pliers, you can reach the plug & unplug it, but actually getting the sensor out is another thing. Just go ahead & do the IAT relocate mod & it will read the incoming air better & be easier to service in the future, if needed.
If it has simply come unplugged, it will be laying between the runners, under the plenum.
1 Post
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: IAT SENSOR!!
locate your ecm. Locate F16 (tan wire). Run a wire from there to the IAT sensor. Now locate your tps. Locate the black wire on it. Splice into the black wire. Now I would run this one to the IAT sensor. That should work out for you.
1 Post
Axle/Gears: 3:42
Re: IAT SENSOR!!
Remember there are three wires coming off of the TPS. One is grey, one is dk blue and the other is the black wire. The other side of that black wire should go back to the ecm, to one of the grounds. You only need to splice into it at the TPS and run the wire to the IAT sensor.
HoosierinWA
10-07-2015 10:15 AM
