safe rpm limit?
safe rpm limit?
i'm woundering what the highest safe rpm that i should push my motor?
my mods are afr 195 heads and a CS XE262H-14 cam
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: safe rpm limit?
If it's a stock shortblock, not rebuilt, about 6200, or 6400 at the most. If it has 100k or more on it, I'd limit to about 6000.
Re: safe rpm limit?
Yeah, i'm running into the same situation on my LT1 swap, the heads I have will support a large cam for serious power, but I stayed with a smaller duration cam so the power was in where I felt the safe limits of the short block to be. The valvetrain should be good to near 7k, but the short block is a stock 68k block out of a Roadmaster. Its a smaller cam at 226/232 on a 110.
Could have gone bigger, but I didn't feel like having a short block go boom and ruin my nice, newly ported heads.
Re: safe rpm limit?
thanks, its a still stock bottom end, for now any way. i just didnt want to push it to far and it go boom. i think i'll keep it under 6k to be safe until i get the bottom done.
thanks for the help
thanks for the help
Re: safe rpm limit?
I just looked at your cam. You probably wouldn't want to spin that cam much past 6k on a 350 anyways. It won't really make much power above 6k, spinning beyond that wouldn't get you any performance gains.
My cam will want to be shifted in the 6200-6400rpm range on a 350. At least, thats what lloyd elliot told me when I ordered it from him. I really didn't want to go north of 6500 on a stock short block. But once I have a short block built I'll replace the cam with a more aggressive cam, by then I should have a 9" or 12 bolt with a better ratio more suited to a larger cam like that.
MikkoV
09-09-2015 04:25 PM
UltRoadWarrior9
09-02-2015 08:24 PM
