Running rich, gas in oil!! Help!
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
My AFR gauge in my car has been reading rich the last few times I drove it. I never saw anything wrong with the car though.
Tonight I checked my oil and its thinned out and smells of gas.
-Fuel pressure while driving is fine, as per my gauge in my car. like 38-42 as always.
-Injectors all ohm at 12-13 hot
-No leaks from Pressure regulator with car on or off
What next?
What next?
Car: 89 formula 350
Re: Running rich, gas in oil!! Help!
im positive the motor is fine. I just need to find whats causing this condition.
Only things I can think of off te top of my head is bad cts, bad injectors or a bad injector wire lol
Car: 89 formula 350
ok so I pressurized the system and clamped the feed and return line for about an hour with no change in pressure.
Car: 89 formula 350
ya it will probably need new plugs too
Car: 89 formula 350
OK so everything scans fine. All sensors read perfect. Figured I might have an exhaust leak. No exhaust leaks to be found while I was under the car. Pulled the cap and rotor to check them
Look fine to me. The problem is definitely still there. Development though: When cold if I get on the gas too much it backfires through the intake. Once it warms up, it has this rich/stumble problem. I'm going to ohm the injectors cold tomorrow and see what they read. Its definitely running rich though...you can smell it at idle.
Changed the oil today too adn nope, no gas in the oil. Muhbad.
I'm at a loss as to what the problem is. Sensors, spark plugs, fuel pressure, everything seems fine. I guess I could throw a ignition module, coil, and cap/rotor at it but those are damn expensive being I need vortech parts.
Maybe bad injectors?
Car: 89 formula 350
While idling I got these temps measured about 1" away from the header flange at the head
#1 160-175*F
#2 170ish*
#3 220-250*F
#4 230-240*F
#5 270ish*F
#6 270ish*F
#7 230-250*F
#8 230ish*F
#1 160-175*F
#2 170ish*
#3 220-250*F
#4 230-240*F
#5 270ish*F
#6 270ish*F
#7 230-250*F
#8 230ish*F
Car: 89 formula 350
this is with a TPIS Miniram, if that makes a difference. I also am using GM Multec 30lb injectors that were factory on the LT4 cars.
Car: 89 formula 350
I see what youre wanting to do but the obd2 scanner is showing no misfires
Car: 89 formula 350
ok so in the morning im going to ohm the injectors cold, and swap plug wires.
Car: 89 formula 350
when cold, all injectors ohm 12.0-12.3 with the exception of #7 that was 11.8
I swapped plug wires with 1/3 and 2/4 and cylinder 1 and 2 are still reading cold.
#1 150-180*F
#2 130-140*F
#3 200-230*F
#4 230-240*F
#5 230*F
#6 250*F
#7 220*F
#8 230*F
I guess next I swap injectors around.
#1 150-180*F
#2 130-140*F
#3 200-230*F
#4 230-240*F
#5 230*F
#6 250*F
#7 220*F
#8 230*F
Car: 89 formula 350
They are not brass.
Swapped 1/3 and 2/4 injectors with no difference in temperature
Car: 1992 z-28
Engine: 383 stealthram
Transmission: auto
Axle/Gears: 4.10
when we are racing I can pull no. 1 and no.2 plugs in about 1 minute after shutting down. my fans cool those cylinders very fast. might be they are cooling from the fan
Car: 89 formula 350
HMM I hadn't thought of that but I'm kinda skeptical about that being the reason. I've had thoughts of header leaks sucking in cool air, or an intake leak.
Still need to pull those plugs and check em tho
Car: 89 formula 350
ok so I've checked and double checked all the sensors and they are fine. compression check shows 160psi in each cylinder. even measured cam lift and the cam is fine.
Put in new plugs and cap and rotor and the car ran much better but is still running pig rich. The inevitable happened and running rich is playing hell on my new plugs and now its running the same.
Seems to be fine at idle and good at WOT (albeit I leave a LOT of smoke at WOT) but part throttle crusing is where the AF gauge reads like 11:1 afr. TEHFUX time to put it away for winter
SO it was fine a while ago and now running rich? Check your ignition module in the dizzy? backfiring thru the intake sounds like a timing problem.
Maybe the cold air just needs retune compared to summer time? You running open loop or closed?
Car: 89 formula 350
how could it be a timing issue? Nothing was ever changed on the car and timing is all done through the pcm.
I wonder if I need a reflash?
I've driven the car in the cold before with no issues. I'm running closed loop
Well if a ignition component goes out, you could be seeing different timing at the engine. Hard to say.
You could try a reflash but its not likely that the ecm would go bad.
Now you are saying OBD-II....is this a 411 ecm swap car? Is the crank sensor good?
Car: 89 formula 350
yeah its a 411 swap. I'm fairly certain that a bad crank sensor causes a no start condition, or at least a code of some sort. I have NO codes and not even any history of codes stored in the pcm.
I do have a chinese aluminum distributor in the car. I was kind of thinking maybe that went bad somehow. I'll check the easy stuff first lol
Car: 89 formula 350
nah its fine. Its been fine almost 3 years now.....something has went south though
Car: 89 formula 350
just pulled the car out of storage to mess with it again. Put a couple O2 sensors in it and it seems to be running much better
Navy8125
08-21-2015 09:32 AM
