clunking sound? exhaust hitting panhard support?
1 Post
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
so when i start my car when its cold, the engine is a little more violent than when its warmed up and theres a noise coming from the rear and it sounds like my exhaust is hitting my panhard support?
ive dropped the car about 3 inches since getting the exhaust done so could this happen because of the lowering?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: clunking sound? exhaust hitting panhard support?
This is one of those "you'll just have to get under it and see" things.
I guess you could put a jack on the tail shaft and raise it a little bit and see if you can see the mount separate. The rubber mounts are notorious for breaking, and they clunk in the transmission tunnel under acceleration.
1 Post
Engine: 5.7 350 TPI
tail shaft meaning the back part near the rear end or the front near the motor?
