Starter won't turn half the time--help asap
Car: 91 Camaro RS
Engine: 305 TBI
I've been having problems getting my 91 rs to start. All of a sudden last week the starter decided not to turn over some times. The car has a new battery and new alternator because those went our earlier. Now it has a new starter and new ignition switch and it is still being a pain. The security light doesn't stay on after the key is first turned and I've tested the clutch safety switch and that was ok. I can turn on the lights and the radio just the starter won't turn. When it does turn the car starts right up and runs fine.
If anyone can help me out with what to look for that would be awesome.
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Starter won't turn half the time--help asap
Most likely the engine is just near peak compression on an compression stroke and hte starter is weak. Fortunately since I have a manual what I would do is throw it in gear and get it rolling a little and pop the clutch to just barely move the engine enough to get it past "the hump". And it'd be fine...
Probably a weak starter or a bad connection though.
Car: 91 Camaro RS
Engine: 305 TBI
Mines a manual to. I can turn the key sometimes and it wont turn. Go back 10 minutes later and it will without rolling the car.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: 1992 Camaro RS
At least since you have a manual you can always push start it! I had a friend who delivered pizzas push starting his car everywhere he went.
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Clean the corrosion off your starter connections. Free repair that could solve your problem.
Engine: 86 Trans AM
Transmission: 5M
Axle/Gears: ?? 2:77 I think??
Car: 91 Camaro RS
Engine: 305 TBI
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
So when you turn the key and the starter does nothing does it at least make a clicking noise. If so diff. a bad/loose connection somewhere.
Car: 91 Camaro RS
Engine: 305 TBI
Car: 1992 Camaro RS
Get a cheap ebay LT1 starter. Even if that doesnt fix your problem they're a huge upgrade.
Car: 91 Camaro RS
Engine: 305 TBI
I cleaned off the leads to the starter with a wire brush and it started 4 times in a row. So hopefully that's solved. Now the brake lights aren't working so im going to get on that right now.
Street Lethal
04-30-2019 12:14 PM
db057
08-11-2015 10:11 PM
