Has my flat tappet wiped a lobe clean, or worse?
Old 07-28-2011, 07:40 AM
Rob 97 Z28's Avatar
Engine: D17A2, L31 based sbc, LS1, LM7
Transmission: 5 spd, built 700r4, T-56, 4L60e
Axle/Gears: 4.11, 3.73, 3.42, 4.56
I have been trying to pin point the origin of a slight tapping sound. First really noticed it in the begining of the month one day when I ran up to the AZ I work at part time. First thought well probablly need to adjust the RRs slightly. I knew if I left it in O/D and layed into it a bit she still detonated a bit, but manually shifting the 700r it was fine. Got around to adjusting all the valves again, first the CHP way then finally with it running. Still that tap/light knock sound. Today after work I thought, quite possibly the header gaskets are completely shot and the bolts have backed themselves out. Took care of all that, some were looser than others.
Fired it up and still, the Sound remains the same...The engine was roughly 130*, just warming up. Shame of it is is that it doesnt even have 4k on it since i built the whole thing & has excellent oil pressure! 75-80psi on a cold start up and at 190-195* its a consistently strong 40-41 psi and the pressure responds immediately with the throttle...took a video sample to get everyones opinion... I know its difficult to tell where and what my camera phone is at, I was just trying to get the phones mic as close to the knock as possible. Seems like its cyl 1 or 3
Youtube link: http://www.youtube.com/watch?v=jyrO_zzEzeM
As far as the oil goes it always look like normal oil, i change it every 2.5 months regardless of miles (usually WELL under 150 miles each time). I run the PH1218 K&N oil filter equivilant along with a 2"x3.5" filter mag. I run Valvoline Max life 10w-30 with a bottle of lucas Zinc additive EVERY oil change. and it doesnt consume any oil at all its always right at the top of the fill line.
Old 07-28-2011, 08:25 AM
Guest
Guest
Posts: n/a
Re: Has my flat tappet wiped a lobe clean, or worse?
Why didn't you check for a wiped lobe while adjusting the rockers? Pop the VCs, lay a straightedge across the tops of the locknuts. Are any of them adjusted way farther down the stud than the others? If so, then those are the lobes and lifters to check, after you verify you're not just pulling a rocker stud.
Old 07-28-2011, 08:29 AM
Rob 97 Z28's Avatar
Having adjusted the valves a few times now I never noticed any one particular rocker lower than its counter rocker for any given cylinder @ TDC...
Old 07-28-2011, 12:48 PM
Guest
Guest
Posts: n/a
I had another thought. The ticking might be a rocker bumping a valve cover?
Old 07-28-2011, 12:51 PM
old z mzn's Avatar
Car: 1992 z-28
Engine: 383 stealthram
Transmission: auto
Axle/Gears: 4.10
had that happen. hit the baffle box ever so slightly
Old 07-28-2011, 01:01 PM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
kind of sounds like lower end to me. hard to tell while hearing it through a camera mike/ computer speakers.
Old 07-28-2011, 02:15 PM
Rob 97 Z28's Avatar
Thats what my gut feeling is... ive had rockers that were a little loose in the past and its more "tick" like sound, this has some "thud" to it...
Old 07-28-2011, 02:30 PM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
i had a connecting rod to crank bearing go out on a chev. 4.3 in an astro van and it sounded just like that.
Old 07-29-2011, 06:44 AM
Rob 97 Z28's Avatar
Thanks for all the input guys! Think I'll be dropping a Blue Print crate engine after this up coming deployment. To many suspension & exterior things to be accomplished already.
gta892000
08-11-2019 11:16 AM
350 IROC-Z
Camaros Wanted
12-18-2015 03:58 PM
Jorlain
10-08-2015 01:57 AM
earlpote
09-12-2015 11:55 AM
MSgt Luttrell
09-05-2015 11:28 AM
Quick Reply: Has my flat tappet wiped a lobe clean, or worse?
