Hydraulic flat tappet cam and LT4 springs
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
14101083 heads on an older block. Had stock springs, a generic cam and Hydraulic Flat tappet lifters.
Im going to put LT4 springs and screw in studs on the heads (I have a spare set) and I was wondering what camshaft could you recommend? I just want something mild and not too expensive (no roller conversion)
Thanks, guys
Thanks, guys
Car: 1992 Firebird
Engine: 350TBI
Re: Hydraulic flat tappet cam and LT4 springs
Comp cams 12-366-4 cam looks like what ill go with. 0.520 max lift with 1.6 rockers and ill probably just be reusing the stock 1.5 rocker arms and I read online the max for the LT4 springs is around 0.525 lift.
If anyone has any comments or suggestions go ahead and speak up, I wont be ordering the cam for a few weeks.
1988iroc350tpi
08-14-2015 07:52 PM
