car starts too fast?
Car: 88' Z
Engine: 350 .60 over
Transmission: W/C T5
is it normal that as soon as i turn the key it fires right up, like i cant even hear it crank. could this be caused by incorrect timing ? another symptom i have is the headers get red hot within a minute of run time. it is a fully rebuilt 350
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: car starts too fast?
I don't know about the quick start, but I wouldn't think it was a bad thing. As for the headers getting red hot, are you meaning a visible orange/red glow or just hot as in you can feel a lot of heat from them? Headers are thinner than stock manifolds and put out more heat, so that would be normal. Glowing orange/red = not so normal.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
could be a major timing issue, or lean
I doubt it is the choke. Sounds way lean to me. What about the water temperature, what's it reading?
the 190 is within 1 minute as well? I am wondering if the overbore has anything to do with it?
Car: 88' Z
no it takes anywhere from 7 to 10 minutes to get at 190 at idle, and im not sure i wouldnt think it would be a problem.
hmmm, those glowing headers are puzzling. Seems lean, but 190 is right on. Are the plugs the correct heat range?
Car: 1986 Z28
Transmission: 700R
Axle/Gears: Stock
I could think of a couple of things that may contribute. how old are the injectors?(you never said if it was tbi tpi or carbureted) May be bad and leaking causing the quick start? A better theory may be low compression from valves/timing being off, taking less time to get the motor spinning fast enough with the starter to run. blow by on the exhaust valves could make combustion occur in the headers, which could cause the glowing headers. check timing first then do compression tests on the cylinders.
Car: 88' Z
what exactly could cause blowby on the exhaust valves, bc i ran open headers for around 300 miles but i always covered the end up after i shut it off
Car: 1991 Pontiac Firebird
Engine: 355 TBI
Transmission: 7004R
Axle/Gears: 3.27/42 ?
Wish my engine started that fast lol
Engine: 305 TBI
Transmission: 5 Speed Manual Transmission
Axle/Gears: Stock
Car: 1986 Z28
Transmission: 700R
Axle/Gears: Stock
Timing as has been said, too much slack in timing chain, weak valve springs, bent valves, or built up carbon on valve seat. Like i said check your compression. i think that's a tool you can borrow from the auto parts store or theyre not expensive to buy
Car: 92 RS 5 speed
Engine: 5.0L TBI
Axle/Gears: 9 bolt rear
db057
08-11-2015 11:11 PM
