Whine Coming From Alternator
Old 07-22-2011 | 10:54 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
I just put a new rectifier (Yes it was rated at the same amps as the old one) in my powermaster alternator that only had 5k miles on it. The original rectifier was blown due to a battery short.
All systems are go, however there is a high pitched whine coming from the alternator that was not there before. Before the rectifier change, it actually did make this same noise although less apparent at low RPMs. Now it does the opposite; the noise becomes prominent at high RPMs but goes silent below about 2k. It sounds like there is a mini supercharger under the hood.
I actually don't mind the noise. The charging system is 100% functional, there is no awful clacking or grinding sound and there is no sight or smell of smoke, but I am concerned something might be amiss here. Thoughts?
Old 07-22-2011 | 11:12 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: Whine Coming From Alternator
both of my powermasters whine like a supercharger
Old 07-23-2011 | 03:52 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
I'd just keep an eye on it to make sure it's not a bearing or bushing about to fail. If all is well and the noise doesn't bother you, drive on!
Cornholio7979
09-20-2018 03:31 AM
Infested
05-23-2018 12:56 AM
Cleotiz
08-23-2015 01:07 PM
eightsixseven
08-14-2015 04:09 PM
Quick Reply: Whine Coming From Alternator
