How much HP can I have?
1 Post
Car: Chevrolet Camaro IROC-Z,96 Vette
Engine: 350 5.7 Liter
Transmission: 700r
I have a 350 that I recently did the top end on. Heres what I did.
Comp 503 Cam. 510,503
Stealth Ram Intake
Patriot Aluminum Heads. 5 angle valve job, 5/16 pushrods, 23 degree heads, intake volume 185-225cc
30lbs accel fuel injectors
Holley Fuel Rail
Stock Thermostat
Stock Throttle Body
Also I ran a 14.3 when the car was stock with rear gears (3:73)
Im getting the car dyno tuned next week and I want to have an idea on what numbers I should be getting with these mods and what my 1/4 could go down too.
Thanks.
Stealth Ram Intake
Holley Fuel Rail
Stock Thermostat
Stock Throttle Body
Thanks.
Car: 1982 Camaro
Engine: 427 BBC
Transmission: Turbo 350
Axle/Gears: Stock rearend
Re: How much HP can I have?
I would say aroun 425 to 450 horses and 450TQ. My buddy has a similar set up with a lil smaller cam hes is only around 460 lift on both exhaust and intake he mad 384HP and 423TQ when we went to the dyno that was with stock heads and TPI. These estimates are at the crank
1 Post
Transmission: 700r
What can my 1/4 be then. These numbers are higher then I thought they be lol
Guest
Posts: n/a
Guest
Posts: n/a
Car: 1982 Camaro
Engine: 427 BBC
Yeah i know they mite be a lil but you shud be pretty close to 400 atleast i have a desktop dyno here to if you could give me the intake Centerline, LSA, and the lift at the cam lobe i cud tell you a lil better.
Guest
Posts: n/a
I have no faith in any version of DD, but the 503 is a 224/230 at 0.050", on a 112 LSA.
http://www.summitracing.com/parts/CCA-08-503-8/
Car: 1982 Camaro
Engine: 427 BBC
The desk top dyno isnt all that bad i do agree that it wont get you exactly what the engine is putting out but mine has been within 10HP and 10TQ of when i took i to the dyno
Guest
Posts: n/a
Car: 1982 Camaro
Engine: 427 BBC
Oh ok thanks i never been real great with all the engine mathmatics of power loss and gear ratios. i just build engines and put them in lol
