Fuel pump won't prime with key
Car: 1987 IrocZ28
Engine: ZZ4 350
Axle/Gears: Australian with 3.73
I have a 1987 iroc Z28 it has a modified 305 tune port injection.
I recently changed the fuel pump and still the car still doesn't start.
It turns over and there is spark at the plugs but it's not starting. I tested the the new pump by using the aldl on the diagnostic linc, but when I use the key the pump still won't prime.
Any help would be greatly appreciated.
Re: Fuel pump won't prime with key
It's possible you've got a flaky ECM (the ECM commands the FP relay at key-on for that 2 second prime). But I'd check the FP relay and it's connections first.
2011 Norwood Gathering
ThirdGen Camaro Rep
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Axle/Gears: 9 bolt 2:77
Check your fuse under the hood located between the battery and the radiator,should be 20 amp.
Car: 1987 IrocZ28
Engine: ZZ4 350
Thanks for the advice but it's not the ECM. I have a second ECM and even with it installed the pump still won't prime with the key! But thanks a lot for your suggestion.
Car: 1987 IrocZ28
Engine: ZZ4 350
