i need detailed directions on how to change a fuel pump
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: i need detailed directions on how to change a fuel pump
Step 1 to working on any car....Buy a repair manual.
If you can get a Factory Service Manual, you'll pretty much never need another one. Or take the easy way out & buy a Chiltons. Just be ready for a lot of misinformation in there. Haynes is a lot better, just not as common to find. I honestly don't know how Haynes stays in business sometimes.
Car: GTA
If you like doing a 6+ hr pump swap, go ahead & do the tank drop method. Once the Access Panel mod is done, it is an under 30 min job from there no out to do then next time it fails. Like 5 min. after your done & find out that the parts store sold you a dead pump. Been there, done that like many others.
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
The Access Panel is the right way & correcting a Factory flaw that some car makers figured out later & stared installing in their cars.
not exactly the same as cutting a big hole where one didnt exist before
Car: 1989 firebird formula
Engine: 5.0L V8
So thanks to the help of the local VIP it is in. But the problem I'm having with my fuel pressure is not fixed. That just leaves the relay. A little help locating it would be good?
Car: GTA
So much for "designed for it" being a plausible argument for it being safe and/or strong if the car was designed or it.
Engine: 4++,350 & 305 CIs
5 years later, zero reinforcement & I have zero problems. Not even in the corners (not round cuts...90 degree cuts). Hell, there was never even a cover made. Just the carper covering the open hole!
Can it be done to be safe? Of course it can but I see and hear of waay 2 many hack jobs. Hard lines cut with a cutofff wheel hacksaw or a sawzall contaminating the lines (then not cleaning it out) and non flared hard lines with hose (not fuel inj rated) and clamps that can blow off the High psi line. Leaving the hole open, thats not a good idea esp if you develop a exhaust leak.
Very few have the time, money or tools to make a access hatch and proper fittings 4 the hard lines.
Just do things correctly. Itll develop good habits an will show with everything else you do to your car.
Oh and buy a factory service manual...
Engine: 5.0L V8
Hard lines cut with a cutofff wheel or a sawzall contaminating the lines and non flared hard lines with hose and clamps that can blow off the High psi line. ..
92camaroJoe
08-13-2015 07:07 AM
