19psi fuel pressure good or bad?
Car: 1989 firebird formula
Engine: 5.0L V8
So I thought my fuel injectors were bad bit I just tested my fuel pressure and it came up to about 19psi is this good or bad? If its bad does that mean. It's the fuel pump? 89' 5.0L
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 19psi fuel pressure good or bad?
And I'd try a 10 minute $10 fuel filter before I dropped the tank to do a pump.
Car: 1992 RS
Engine: Carbed 350
"relatively new" would matter if they were age dependant, but they are dirt dependant - even a one week old filter could be clogged already depending on what kind of gunk is floating around in the tank. Especially given that the fuel pump socks often rot into nothing from the gas exposure.
I'm just saying that I'd much rather try another filter before I dropped the tank or cut the access hole - especially when it's only 10 minutes and $10.
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Were you testing the fuel pressure with the car running in park and the pressure regualtor hose disconnected and plugged as to simulate WOT? IF so, you should be getting 43.5 psi. That is supposedly stock
Engine: 5.0L V8
The car was in park and I didn't disconnect anything. It was going from 19-35 almost 40 the gauge was moving iradically (spell check?) And wouldn't stop. Also what is WOT?
Axle/Gears: 3:42
WOT is wide open throttle. If you disconnect the hose on your fuel pressure reg. and plug it with a screw or something then it will simulate your fuel pressure at wide open throttle. Does your gauge have another small hose coming off of it to bleed out air? Also check the connector on your gauge where it connects to your schrader valve. Make sure there are no leaks on your gauge. Did you check the pressure with the car running like you are supposed to?
R3500
08-17-2015 01:16 PM
92camaroJoe
08-13-2015 07:07 AM
